XV B body engine bay brace #2490005
04/30/18 02:48 PM
04/30/18 02:48 PM
Colorado
Bob J Offline OP
Bob J  Offline OP
Colorado
Any one running a XV B body engine bay brace? I want to run one with a big block and Elderbrock Pro Flow XT intake. My question is will this fit as is or could the front bar be modified to fit? XV Engine Bay Brace
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: XV B body engine bay brace [Re: Bob J] #2490210
05/01/18 12:33 AM
05/01/18 12:33 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
A buddy offered me one that he was going to use in his 70 GTX. It won't fit my car because of my power brakes.
Re: XV B body engine bay brace [Re: Bob J] #2490256
05/01/18 02:43 AM
05/01/18 02:43 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
That front bar is going to be where the XT throttle body wants to live as well
Re: XV B body engine bay brace [Re: Bob J] #2490356
05/01/18 11:50 AM
05/01/18 11:50 AM
Colorado
Bob J Offline OP
Bob J  Offline OP
Colorado
Yep it's that front bar that is the problem. I'm not running a distributor just the cam sensor from Andy F. So I may be able to lower the front bar to go blow the throttle body. Cut the front bar up and sleeve it or have a custom front bar made. The dash is built and about to go in so now is the time to make a choice on this.
Re: XV B body engine bay brace [Re: Bob J] #2490724
05/02/18 01:05 AM
05/02/18 01:05 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I wonder what the actual gain might be by using it. Maybe with frame connectors, the lower radiator U brace and the inner fender gussets, this may not help all that much. If it blocks access and you are not looking for that 5% of additional stiffness it provides, is it worth the effort?
Re: XV B body engine bay brace [Re: Bob J] #2490728
05/02/18 01:07 AM
05/02/18 01:07 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
I’ll try to dig up a picture from when I had an XT in my car. The throttle body angles down so I doubt you could get a bar under it. Let me put it this way, you will need a 90 degree thermostat housing to clear the throttle body
Re: XV B body engine bay brace [Re: Bob J] #2490731
05/02/18 01:11 AM
05/02/18 01:11 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
Here you go
Re: XV B body engine bay brace [Re: Kern Dog] #2490745
05/02/18 01:37 AM
05/02/18 01:37 AM
Colorado
Bob J Offline OP
Bob J  Offline OP
Colorado
I already have the frame connectors and radiator support welded in. I have the inner fender supports but not in yet. I just welded up the inner cowl and A pillar. I also welded up the steering support bracket that is welded to the cowl. On that bracket, with no other support that bracket would move a lot with it's few spot welds. After welding it up the cowl no longer flexed and the bracket was solid. I also welded up the K frame with the steering box support.
I'm working with a convertible so I'm trying to make the car stiffer. Yep a hardtop would be stiffer but this is the car that I have, plus I'm 6'6" so dammit I want some head room with a helmet on for once.
So this looks like something that I'm going to pass on. Thank you every body for your input.
Bob
Re: XV B body engine bay brace [Re: Bob J] #2490838
05/02/18 11:45 AM
05/02/18 11:45 AM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
I can't recall the specific issues, but we got one to install on a 69 GTX once and the fit was absolutely terrible. We abandoned it after messing with it for a half a day.
