Trans rebuild what did I forget? #2489187
04/28/18 07:16 PM
04/28/18 07:16 PM
GoDartGo Offline OP
GoDartGo  Offline OP
TF 727 trans rebuild what did I forget? It's not the output shaft clip.
Re: Trans rebuild what did I forget? [Re: GoDartGo] #2489196
04/28/18 07:47 PM
04/28/18 07:47 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
Shifter/selector shaft? That seal looks familiar.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Trans rebuild what did I forget? [Re: GoDartGo] #2489198
04/28/18 07:57 PM
04/28/18 07:57 PM
GoDartGo Offline OP
GoDartGo  Offline OP
Well, it's a flat washer.
Re: Trans rebuild what did I forget? [Re: GoDartGo] #2489216
04/28/18 08:56 PM
04/28/18 08:56 PM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
kickdown shaft seal has a washer on top of it and an E clip, not an inside snap ring
it could a clip from the governor maybe
what size is it and is it a steel washer or fiber washer
Re: Trans rebuild what did I forget? [Re: GoDartGo] #2489314
04/29/18 12:56 AM
04/29/18 12:56 AM
GoDartGo Offline OP
GoDartGo  Offline OP
steel, not sure the size yet. the fiber flat washer is already on.
Re: Trans rebuild what did I forget? [Re: GoDartGo] #2489319
04/29/18 01:05 AM
04/29/18 01:05 AM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
I'd wait for John Kunkel to chime in before proceeding. Dude knows transmissions.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Trans rebuild what did I forget? [Re: GoDartGo] #2489320
04/29/18 01:10 AM
04/29/18 01:10 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Only 2 inside snap rings in a 727 are for the governor weights.
Doug
Re: Trans rebuild what did I forget? [Re: GoDartGo] #2489481
04/29/18 01:26 PM
04/29/18 01:26 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Snap ring and washer from the front servo, should be a spring also. Goes in piston after the pin that pushes the band apply lever.
Re: Trans rebuild what did I forget? [Re: qwkmopardan] #2489631
04/29/18 07:02 PM
04/29/18 07:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
iagree
Re: Trans rebuild what did I forget? [Re: GoDartGo] #2489662
04/29/18 08:19 PM
04/29/18 08:19 PM
GoDartGo Offline OP
GoDartGo  Offline OP
Thanks! I used the older style. Don't even know how that snap ring and washer got on the table.
Re: Trans rebuild what did I forget? [Re: GoDartGo] #2489868
04/30/18 10:12 AM
04/30/18 10:12 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Good call, forgot about that ring.
Doug
