Page 5 of 6 1 2 3 4 5 6
Re: Drilling leaf springs [Re: mopar dave] #2492349
05/05/18 10:45 AM
05/05/18 10:45 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
To make full use of my yoke I could make my driveshaft 2" longer and still have room to back it out of the axle with 3/4" to clear the cap that is 1/2" deep on the pinion.Do you know what you have yet?
Re: Drilling leaf springs [Re: Clanton] #2492360
05/05/18 11:01 AM
05/05/18 11:01 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
no. been busy. If i have time today i will pull the shaft out and measure the slip yoke. Looks like my drive shaft is 1" too short at the moment. Gonna call strange if i need a new shaft.
Re: Drilling leaf springs [Re: mopar dave] #2492363
05/05/18 11:11 AM
05/05/18 11:11 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I am lucky there is a place near me Custom clutch and u joint in Cleveland I just drive to in 30 minutes.Keep us posted.
Re: Drilling leaf springs [Re: Clanton] #2492378
05/05/18 11:47 AM
05/05/18 11:47 AM
Mt Morris Michigan
Mt Morris Michigan
Ok, i have some pics. now, from the base of that slip shaft to the edge of the boot measures 2", but the main shaft is out past the boot 1/4".
Re: Drilling leaf springs [Re: mopar dave] #2492379
05/05/18 11:50 AM
05/05/18 11:50 AM
Mt Morris Michigan
Mt Morris Michigan
couple more. The yoke is splined to the bottom and measures 5.5" deep.
Re: Drilling leaf springs [Re: mopar dave] #2492380
05/05/18 11:53 AM
05/05/18 11:53 AM
Mt Morris Michigan
Mt Morris Michigan
couple more. The u joint measures 3" from the pinion saddle.
Re: Drilling leaf springs [Re: mopar dave] #2492381
05/05/18 11:53 AM
05/05/18 11:53 AM
Mt Morris Michigan
Mt Morris Michigan
what length of drive shaft should i order?
Re: Drilling leaf springs [Re: mopar dave] #2492570
05/05/18 10:42 PM
05/05/18 10:42 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I think if you put a jack under the pinion the length will be a little shorter but maybe only 1/4".No takers on the length?
Re: Drilling leaf springs [Re: mopar dave] #2492571
05/05/18 10:45 PM
05/05/18 10:45 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
So that 3" is with the yoke all the way in the trans?
Re: Drilling leaf springs [Re: mopar dave] #2492576
05/05/18 11:02 PM
05/05/18 11:02 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
If you order from Dr. Diff, he asks for two measurements, and some other questions, of course. But Idk if you have to call to have something other than a 1350 joint shaft made.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Drilling leaf springs [Re: Clanton] #2492590
05/05/18 11:27 PM
05/05/18 11:27 PM
Mt Morris Michigan
Mt Morris Michigan
yes, with it all the way into the trans. I calculate 2 3/4 of spline engagement statically. Probably 3" under load. Enough or do i need a new drive shaft?
Re: Drilling leaf springs [Re: mopar dave] #2492597
05/05/18 11:39 PM
05/05/18 11:39 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I would go with a 46" ds but I fear the rubber boot is still holding the yoke out.
Re: Drilling leaf springs [Re: Clanton] #2492599
05/05/18 11:42 PM
05/05/18 11:42 PM
Mt Morris Michigan
Mt Morris Michigan
The boot flattens out when i slide the yoke all the way in.
Re: Drilling leaf springs [Re: mopar dave] #2492600
05/05/18 11:43 PM
05/05/18 11:43 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
The cove on the yoke should go to the trans housing not the boot so you need to add the boot length.
Re: Drilling leaf springs [Re: mopar dave] #2493188
05/07/18 02:00 PM
05/07/18 02:00 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I would think if you took your measurement with the yoke cove just back from the boot 1/4" to 1/2" the length would be good to pull the u joint from the pinion and have room.I think this will give you the 1" you want to be able to move it.
Re: Drilling leaf springs [Re: Clanton] #2493229
05/07/18 03:10 PM
05/07/18 03:10 PM
Mt Morris Michigan
Mt Morris Michigan
Yep, yur right. Just spoke with Dynotech drive shafts and they suggest 1" from pinion yoke. Shaft should be 45.5" to be correct. 2 3/4" Spline contact is enough for strength. The problem is with the front u joint to far away from the tail shaft bushing support.
Re: Drilling leaf springs [Re: mopar dave] #2493246
05/07/18 03:58 PM
05/07/18 03:58 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Thank you for your information you got!How much do you think a new shaft with ends and joints will cost?250$Wait I bet with new ends,ballance will be more like 350$
Re: Drilling leaf springs [Re: mopar dave] #2493256
05/07/18 04:12 PM
05/07/18 04:12 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
My guy said 335+tax 3.5" mild steel new ends,joints weld balance 2 days tops.
For anyone in the area 216-431-1630 3417 St Clair Ave Cleveland Custom clutch n joint
Re: Drilling leaf springs [Re: Clanton] #2493309
05/07/18 06:17 PM
05/07/18 06:17 PM
Mt Morris Michigan
Mt Morris Michigan
No problem. My current drive shaft is from Dynotech. They quoted me $415 without slip yoke. Gonna call Strange yet. Thanks
Re: Drilling leaf springs [Re: mopar dave] #2493319
05/07/18 06:40 PM
05/07/18 06:40 PM
est
huimerind Offline
huimerind  Offline
est
Sorry, if off topic, but how thick is the caltrac mono leaf front segment?
