65 383 HP #2471227
03/24/18 03:57 AM
03/24/18 03:57 AM
Loganville GA.
K
kdsmith07 Offline OP
K
Loganville GA.
i have a 65 383 block stamped hp and was wondering what year they started stamping hp on the blocks?tia
Re: 65 383 HP [Re: kdsmith07] #2471252
03/24/18 10:08 AM
03/24/18 10:08 AM
NC
Sixt8Chrgr Offline
Sixt8Chrgr  Offline
NC
1965, should also have an "A" stamped on the pad.
1965 A
1966 B
1967 C
1968 D
1969 E
So forth
Re: 65 383 HP [Re: kdsmith07] #2471317
03/24/18 12:50 PM
03/24/18 12:50 PM
Loganville GA.
K
K
Loganville GA.
it is stamped A383 but it has the HP in the bottom right corner.my question is what year did they start the HP stamping?thanks
Re: 65 383 HP [Re: kdsmith07] #2471606
03/24/18 11:53 PM
03/24/18 11:53 PM
Loganville GA.
K
K
Loganville GA.
ok,let me rephrase the question.what's the earliest hp block you've seen?
Re: 65 383 HP [Re: kdsmith07] #2472339
03/26/18 03:45 PM
03/26/18 03:45 PM
dogdays Offline
dogdays  Offline
A '62 413 with HP stamp.
R.
Re: 65 383 HP [Re: kdsmith07] #2472380
03/26/18 04:59 PM
03/26/18 04:59 PM
Loganville GA.
K
K
Loganville GA.
thanks R.
Re: 65 383 HP [Re: dogdays] #2488911
04/28/18 12:55 AM
04/28/18 12:55 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
R.
WRONG! A1961 300 engine has HP stamped it.
Re: 65 383 HP [Re: NANKET] #2489021
04/28/18 12:16 PM
04/28/18 12:16 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
R.
So was the 59 300E !
Re: 65 383 HP [Re: kdsmith07] #2489072
04/28/18 02:29 PM
04/28/18 02:29 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
1959 300 has MR413 stamped on the pad. Does it have HP also?
Re: 65 383 HP [Re: NANKET] #2489122
04/28/18 04:46 PM
04/28/18 04:46 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
It did when I owned it !
Re: 65 383 HP [Re: 62maxwgn] #2489993
04/30/18 02:34 PM
04/30/18 02:34 PM
dogdays Offline
dogdays  Offline
The question was what's the oldest HP block that you have seen. The '62 was the oldest I had seen.
There's the question and there's my correct answer.
Others may have seen earlier, they can speak for themselves.
R.
