Anyone running the Trans-Dapt /6 to v8 swap mounts? #2488109
04/26/18 05:38 AM
04/26/18 05:38 AM
Ohio
moparjoe360.4 Offline OP
Ohio
I’m looking at different options for putting my 410 stroker into my recently aquired 71 Duster and ran across the Trans-Dapt Performance Engine Swap Motor Mounts 4695, they’re 1/2 the price of the Schumacher a67a6 A body V8 conversion mounts. Cheaper isn’t always better though so I figured is see if anyone here had run them. I also plan on putting headers on it so those have to clear everything too. I might also just swap to a V8 K member. Any help would be appreciated.
Re: Anyone running the Trans-Dapt /6 to v8 swap mounts? [Re: moparjoe360.4] #2488324
04/26/18 04:09 PM
04/26/18 04:09 PM
Chicago adjacent
WS68SSC Offline
Newest
WS68SSC  Offline
Newest
Chicago adjacent
no
Re: Anyone running the Trans-Dapt /6 to v8 swap mounts? [Re: moparjoe360.4] #2488435
04/26/18 08:33 PM
04/26/18 08:33 PM
Ohio
Ohio
Wow.... I figured this was the place to ask a question like that. Guess I’ll stick to the unlawful’s race section.
Re: Anyone running the Trans-Dapt /6 to v8 swap mounts? [Re: moparjoe360.4] #2488492
04/26/18 11:32 PM
04/26/18 11:32 PM
Joe I ain't used em but here is a BTT for ya & I hope someone has some exp with em to share with you.
Re: Anyone running the Trans-Dapt /6 to v8 swap mounts? [Re: moparjoe360.4] #2488590
04/27/18 08:56 AM
04/27/18 08:56 AM
Ohio
Ohio
Thanks Robert! This is a lint to them on Summits site.
https://www.summitracing.com/parts/trd-4695
Re: Anyone running the Trans-Dapt /6 to v8 swap mounts? [Re: moparjoe360.4] #2488808
04/27/18 08:25 PM
04/27/18 08:25 PM
dogdays Offline
dogdays  Offline
Back in the day the Trans-dapt stuff was the only game in town unless you had a welder. Some of it was downright shoddy. But, comparing the two versions of the mounts, I don't see much difference. Both use rubber insulators, the Schumacher adapters are powder coated while Trans-dapt are not.
There may be a difference in how easily the holes line up. There may be a slight difference in metal thickness. But overall they look quite the same.
R.
Re: Anyone running the Trans-Dapt /6 to v8 swap mounts? [Re: moparjoe360.4] #2488965
04/28/18 09:01 AM
04/28/18 09:01 AM
Ohio
Ohio
Thanks, I think I’m going to give them a try!
