Re: oil pump for hemi with lowish hot oil pressure [Re: 71birdJ68] #2489372
04/29/18 03:52 AM
04/29/18 03:52 AM
I think one .060 washer will raise the bypass pressure up to over 100 Lbs. at idle cold on a high volume pump with the high pressure black spring shruggy
It has been a long, long time since I tried adding pressure to those pumps, I usually cut one to two coils off the black springs to get 10 Lbs. per 1000 RPM with hot oil over 160 F shruggy
I think Mellings and Speed Pro are now, for the last two or two and half years, installing standard pressure springs in there high volume pumps instead of the high pressure springs, maybe not confused shruggy
Re: oil pump for hemi with lowish hot oil pressure [Re: hemi-itis] #2489393
04/29/18 08:54 AM
04/29/18 08:54 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
That looks like the ticket.
Re: oil pump for hemi with lowish hot oil pressure [Re: ogopogo] #2489463
04/29/18 11:41 AM
04/29/18 11:41 AM
fredericksburg,va
cudaman1969 Offline
Itch Nutz
cudaman1969  Offline
Itch Nutz
fredericksburg,va
To my knowledge all 66-71 Hemis came stock with the so called high volumn pump, same one that comes over the counter now. Actually there are two stock pumps, one for b motors (thin) and Hemi (thick). There are some good aftermarket pumps that will feed a monster engine. If your engine ran perfect I'd still pull apart to inspect, like one guy said Hemi = $$$$$
Re: oil pump for hemi with lowish hot oil pressure [Re: ogopogo] #2490090
04/30/18 05:37 PM
04/30/18 05:37 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Originally Posted By ogopogo
I recently aquired a 426 mopar crate hemi that apparantly ran really well/strong,but has lowish oil pressure when hot.it came to me minus oil pump so I am going to order a pump for it today.Should i get stock replacement or hi psi or hi volume pump for it? i plan to run it as is for now...
Do you have any idea as to what era crate hemi it is? The Cummins motors are the worst.
Mainstream Media is the new Pravda
Re: oil pump for hemi with lowish hot oil pressure [Re: ogopogo] #2490120
04/30/18 07:20 PM
04/30/18 07:20 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
hemi's came with the standard length rotors. there were two pressure relief springs; the black 65lb street hemi and plain (no color) 75lb race hemi. the Ramchargers marketed a tall rotor with a spacer back in the '60's that fit in a stock pump housing. pretty sure the tall rotors that we all think of as high volume were actually Ford FE rotors.
Re: oil pump for hemi with lowish hot oil pressure [Re: hemi-itis] #2490141
04/30/18 08:39 PM
04/30/18 08:39 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
that adjuster is worth every dime of it,, love mine. up
Re: oil pump for hemi with lowish hot oil pressure [Re: ogopogo] #2490316
05/01/18 09:23 AM
05/01/18 09:23 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
back in the day we used to drill and tap the relief spring cap for 3/8"-24 and use a set screw with a jam nut to adjust pressure. fairly simple and cheap.
