Re: oil pump for hemi with lowish hot oil pressure
[Re: 71birdJ68]
#2489372
04/29/18 04:52 AM
04/29/18 04:52 AM
Posts: 43,744 Bend,OR USA
Cab_Burge
I think one .060 washer will raise the bypass pressure up to over 100 Lbs. at idle cold on a high volume pump with the high pressure black spring It has been a long, long time since I tried adding pressure to those pumps, I usually cut one to two coils off the black springs to get 10 Lbs. per 1000 RPM with hot oil over 160 F I think Mellings and Speed Pro are now, for the last two or two and half years, installing standard pressure springs in there high volume pumps instead of the high pressure springs, maybe not
[Re: ogopogo]
#2490090
04/30/18 06:37 PM
04/30/18 06:37 PM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
I recently aquired a 426 mopar crate hemi that apparantly ran really well/strong,but has lowish oil pressure when hot.it came to me minus oil pump so I am going to order a pump for it today.Should i get stock replacement or hi psi or hi volume pump for it? i plan to run it as is for now... Do you have any idea as to what era crate hemi it is? The Cummins motors are the worst.
Mainstream Media is the new Pravda
