Hellcat supercharger on a 6.4 Hemi
#2487288
04/24/18 02:14 PM
04/24/18 02:14 PM
Posts: 50 Where else?
BigHemiVegas
Where else?
Has anybody put a Hellcat supercharger on a 6.4 engine. Would it make the 700 HP that the Hellcat engine makes with the proper cam swap OR is there more to the Hellcat short block?
What would be needed to run the hellcat supercharger on a 6.4 Hemi?
Re: Hellcat supercharger on a 6.4 Hemi
[Re: BigHemiVegas]
#2487309
04/24/18 02:47 PM
04/24/18 02:47 PM
Posts: 666 IL
Dart451
IL
Believe the intake bolt pattern is different, and need new pistons and rods.
I just learning the gen3 hemi stuff also.
I ordered this book yesterday by Larry Shepard
SA404 New Hemi Engines 2003 to Present: How to Build Max Performance
Hopefully a good read.
I meant to follow up on your big block thread when i posted hellcrate was best option, went on vacation and forgot about it till now
[Re: BigHemiVegas]
#2487316
04/24/18 02:59 PM
04/24/18 02:59 PM
Posts: 12,406 Kalispell Mt.
HotRodDave
Kalispell Mt.
You gots to swap on the hellcat heads or possibly drill the bolt holes in the apaches, dont know if theres enough meat and the alloy is not as good at conducting away the extra heat. Different front cover arangement also.
You will have more compression so you will neeed more octane. The apache cam has a tiny bit more lift and a lot less exhaust duration.
If you just bolt it on you could have similar power maybe even a tad more TQ, but you WILL need more octane, probably 100 octane. Even so your cast pistons will be living on borrowed time. Also the block will probably be just fine BUT the BGE block used on the hellcat and truck 6.4 does have slightly revised coolant flow for better cooling with all the extra heat as well as the cylinders are siamesed about 1/2 way up to make them more stable as well as the ribs on the outside.
[Re: BigHemiVegas]
#2487318
04/24/18 03:03 PM
04/24/18 03:03 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
The edelbrock heads are also drilled for a hellcat supercharger. The hellcat heads are pretty pricey to buy new.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: HotRodDave]
#2487333
04/24/18 03:17 PM
04/24/18 03:17 PM
BigHemiVegas
Where else?
If you just bolt it on you could have similar power maybe even a tad more TQ, but you WILL need more octane, probably 100 octane. Even so your cast pistons will be living on borrowed time. Also the block will probably be just fine BUT the BGE block used on the hellcat and truck 6.4 does have slightly revised coolant flow for better cooling with all the extra heat as well as the cylinders are siamesed about 1/2 way up to make them more stable as well as the ribs on the outside. Wow I learn something new all the time about Gen III Hemis. I did not know the Hellcat cylinder head had a completely different bolt pattern and I did not know the front of the Hellcat block had a diffrent front plate front cover as well. Sounds like Hellcat is its own engine and has barely anything to do with the regular 5.7,6.2 or 6.4 Hemis. I was going to try and build a "Hellcat engine"starting with regular 6.2 or 6.4 engine. Sounds like they are way too different. That is good info and thanks.
[Re: BigHemiVegas]
#2487338
04/24/18 03:35 PM
04/24/18 03:35 PM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
I think your best bet would be to just add a pro-charger or whipple. Easy to find in kit forum and should make some real good power.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: BigHemiVegas]
#2487340
04/24/18 03:43 PM
04/24/18 03:43 PM
Posts: 30 Bowling Green, KY
BlakDak71
Bowling Green, KY
The intake bolt pattern is different on Apache vs Hellcat heads, and there isn't enough meat to redrill Apaches for it.
With that said, a 6.4 big gas truck block is the same block as a 6.2 Hellcat. In fact, Hellcat blocks have a BGE stamp on the casting, they're just powdercoated orange.
Hellcat has a unique front cover which requires a unique oil pan. Along with this, running the Hellcat blower would require the entire cooling system for both it (reservoir, low temp radiator pump, both in line low temp radiators), and the HC runs an air/air oil cooler that is recommended to run even on Hellcrate engines.
You'd have to swap pistons and rods out for something stronger and probably lower compression...at this point you'd be better off getting a 6.2 motor and just swapping the crankshaft for a 6.4 crankshaft lol.
[Re: BigHemiVegas]
#2487341
04/24/18 03:47 PM
04/24/18 03:47 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
The Apache heads don't have enough material in the area you need to drill to use them with the Hellcat intake/supercharger, the Hellcat cam has more Exhaust Duration then the SRT392 cam, If I remember correctly it's also a smaller lift on the intake(557 Vs 571).vs the SRT392 cam (not my photo) in the photo you can see where the Hellcat intake bolts and where the Apache intake , bolt holes are not drilled. The company I work for had some Hellcat engines in for testing, one dropped a valve and we tried to replace it with an Apache head, no good kept cracking where we drilled for the Supercharger/intake bolts
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
