AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? #2484625
04/18/18 02:30 PM
04/18/18 02:30 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Overheard conversation the other day, about how well those worked in a customer's old vehicle.
Wondering if they're good for MoPar engines, such as the LA and B engines.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? [Re: Magnumguy] #2484627
04/18/18 02:32 PM
04/18/18 02:32 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ran regular ACs in Gms at work.Mopars we ran and I run either Autolites or NGKs.NGKs in my 65 run great and its 12.5 compression street driven.Rocky
Chrysler Firepower
Re: AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? [Re: Magnumguy] #2484649
04/18/18 03:15 PM
04/18/18 03:15 PM
Chicago
PurpleBeeper Offline
Chicago
No, they are not worth the extra money. Marketing hype
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? [Re: PurpleBeeper] #2484726
04/18/18 06:02 PM
04/18/18 06:02 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I run NGK or Denso plugs in my Mopars shruggy They seem to last forever and I get them cheap from work biggrin
Gus beer
64 Plymouth Savoy
Dana 60
Re: AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? [Re: PurpleBeeper] #2484727
04/18/18 06:07 PM
04/18/18 06:07 PM
an8sec70cuda Offline
iagree Get the correct plug for your motor, not the latest gimmick. I use NGKs normally, but have had good service from all different brands of conventional plugs.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? [Re: Magnumguy] #2484778
04/18/18 08:05 PM
04/18/18 08:05 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
My opinion is the absolute best plugs are Iridium, but in reality they are quite pricey and also not too many people are driving a ton of miles on their classic mopar. So the only advantage would be the smaller electrode is somewhat less likely to misfire.
I doubt you'd notice a difference.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? [Re: Magnumguy] #2484785
04/18/18 08:28 PM
04/18/18 08:28 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
That Delco design plug has more sharp edges to lower the peak KV to get the spark to start.
They have not worked noticeably better for me.
I prefer the expensive irridium alloy tiny tips, either NGK or Denso.
They both start the spark at lower KV and allow a much larger spark gap that allows a faster burn and less advance before top dead center.
Re: AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? [Re: 360view] #2484823
04/18/18 09:34 PM
04/18/18 09:34 PM
IN
ahy Offline
ahy  Offline
IN
I run NKG's in my MOPAR (standard type). Works fine. Autolights in a classic PU. Works fine.
Platinum plugs, OE style, in late model DD's.
The platinum plugs offer up to 100k mileage which is relevant in a DD. In a hot rod, what is the point? Plugs will usually be changed for some reason well before high mileage is reached. Heat range may be wrong. They may be fouled. Or as preventative maintenance.
Re: AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? [Re: Magnumguy] #2484876
04/18/18 11:15 PM
04/18/18 11:15 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Basic Champion for my old stuff.
Angry white pureblood male
Re: AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? [Re: Magnumguy] #2484982
04/19/18 09:53 AM
04/19/18 09:53 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Just dont get Bosch.Total s--t plugs in almost every car they were installed in.I cant say hw many sets I had to pull ecause they ran bad.Cant see how they still make them.Rocky
Chrysler Firepower
Re: AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? [Re: Magnumguy] #2484986
04/19/18 10:09 AM
04/19/18 10:09 AM
S.E.Ohio
S.E.Ohio
Thanks y'all
Re: AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? [Re: Magnumguy] #2485162
04/19/18 04:33 PM
04/19/18 04:33 PM
dogdays Offline
dogdays  Offline
The Rapidfire plugs were developed to cut down on irregular misses by GM engineers who were doing a lot of emission testing and monitoring cylinder-by-cylinder. I believe there are a couple of SAE papers about this. So it is not all smoke and mirrors.
The question of whether you'd notice it on a dyno or racetrack is still up in the air, I'd say probably not. But that isn't measuring as precisely as the tests used to develop the plugs.
If they work in one engine they'll work in others.
I put a new set of highest-end NGK Iridium plugs in my Hyundai and noticed exactly NO mpg increase over the 100K plugs they replaced. When I pulled them out a year later one had the thin wire missing, one had it apparently welded to the ground strap instead of the center electrode, and the other two were OK. Kind of disappointing.
In real life situations, unless the current ignition system is failing or faulty there isn't a whale of a lot of power to be had by any trick ignition.
R.
Re: AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? [Re: dogdays] #2485297
04/19/18 10:03 PM
04/19/18 10:03 PM
Rittman Ohio
Rittman Ohio
I run the Denso Iridium plugs with the thin electrode and they work perfect in my engine. I just picked this plug by happenstance at work one day. I had My Indy heads on the bench at work assembling them and I was doing a tune-up on a new Tundra and just screwed a plug in my Indy head they fit perfect and I just put them in for break in. They ran perfect on the initial test drive so I left them in and I'm on my second set in 5 years thumbs
Gus beer
64 Plymouth Savoy
Dana 60
Re: AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? [Re: Magnumguy] #2485448
04/20/18 04:44 AM
04/20/18 04:44 AM
southeast NE
lemondana Offline
lemondana  Offline
southeast NE
AC plugs suck in Mopars!
Re: AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? [Re: PurpleBeeper] #2485501
04/20/18 10:51 AM
04/20/18 10:51 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Agreed. Also I have found in my experience that 95% of plugs get changed for no good reason (I'm guilty of this as well). Most can just be cleaned and reinstalled.
Re: AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? [Re: dogdays] #2486016
04/21/18 11:44 AM
04/21/18 11:44 AM
USA
3
360view Offline
360view  Offline
3
USA
R.
I believe there is a US Patent Number on the Rapidfire spark plugs package that you can look up and read on Google’s Patent service. Patents usually have a “History of the Invention” section that is well worth reading and points out key past improvements in spark plugs.
Re: AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? [Re: ruderunner] #2486197
04/21/18 10:05 PM
04/21/18 10:05 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Me too.
I have mechanical Aptitude.
I can screw up anything.
Re: AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? [Re: bboogieart] #2486199
04/21/18 10:14 PM
04/21/18 10:14 PM
Rittman Ohio
Rittman Ohio
Me too.
I don't even put Champion plugs in my lawnmower anymore twocents
If there is a better plug out there then why not use it shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? [Re: fourgearsavoy] #2486202
04/21/18 10:16 PM
04/21/18 10:16 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
They work... shruggy
Re: AC DELCO RAPID FIRE PLUGS, WORTH THE $ ? [Re: bboogieart] #2488413
04/26/18 07:21 PM
04/26/18 07:21 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Most champions I have changed were due to resistance being too high causing a miss, they use crappy resisters....and almost no one checks the resistance of their plugs with a meter. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
