69 Road Runner fan resistor network #248526
03/09/09 03:25 PM
03/09/09 03:25 PM
Table Rock Lake Missouri
furious Offline OP
furious  Offline OP
A friend is finishing up his 69 Road Runner with A/C. He said the fan resistor network, mounted on top of the heater box is all busted up. Can someone tell me where to buy a new one, or at least a good used one? Thanks!
Re: 69 Road Runner fan resistor network [Re: furious] #248527
03/09/09 05:49 PM
03/09/09 05:49 PM
furious Offline OP
furious  Offline OP
Re: 69 Road Runner fan resistor network [Re: furious] #248528
03/09/09 08:33 PM
03/09/09 08:33 PM
Ball Ground GA
TrueTripleX Offline
TrueTripleX  Offline
Ball Ground GA
I am not sure what part you are describing that is on TOP of the box. Is this the item or so you have a picture you could PM to me?
Re: 69 Road Runner fan resistor network [Re: TrueTripleX] #248529
03/09/09 08:57 PM
03/09/09 08:57 PM
furious Offline OP
furious  Offline OP
Thanks very much for your response. It is the wire wound resistors that control the different fan speeds. It is where the three wires hook up, the resistors actually end up inside the box.
Re: 69 Road Runner fan resistor network [Re: furious] #248530
03/10/09 06:02 PM
03/10/09 06:02 PM
furious Offline OP
furious  Offline OP
Anyone know or rebuilt a heater box with one of these?
Re: 69 Road Runner fan resistor network [Re: furious] #248531
03/10/09 06:24 PM
03/10/09 06:24 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Rebuild the heater box? The resistor plate is held in with two screws. Do a search for blower motor resistor and If anybody sells them they should show up. Try Ebay.
Re: 69 Road Runner fan resistor network [Re: stumpy] #248532
03/10/09 10:39 PM
03/10/09 10:39 PM
furious Offline OP
furious  Offline OP
Thanks, great advice!
