Re: Drilling leaf springs
[Re: mopar dave]
#2486179
04/21/18 08:40 PM
04/21/18 08:40 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
When I drilled mine, I used a center cutting end mill. That and a Bridgeport, but I would think a heavy drill press would do the same thing. I was surprised at how easy they were to drill. I always thought they were made of stronger stuff.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: mopar dave]
#2486206
04/21/18 10:21 PM
04/21/18 10:21 PM
poboyengineering
pennsylvania
The end mill did it in one step. If you burned up a lot of bits, you may have hardened the metal right near the hole.
[Re: mopar dave]
#2488893
04/28/18 12:02 AM
04/28/18 12:02 AM
poboyengineering
pennsylvania
Speeds and feeds will get you every time. Glad to see you got it sorted out.
[Re: mopar dave]
#2489016
04/28/18 11:56 AM
04/28/18 11:56 AM
Posts: 19,383 north of coder
moparx
an interesting story regarding speeds and feeds. my brother installed a railing in a house he owned one time. just one of those cheapy, imported, lumber house specials. not thick steel by any standards, maybe .094-.100 at best. all the holes drilled ok until the last one. it was a real toughie ! my brother thought it was a combination of imported steel, who knows quality of the bit, and the fact there was many holes drilled with a used bit to start with. anyway, he just gives it all he got and finally, got it pushed through [hand drill of course]. the hole looked like he used a torch of some kind to blow it through, and the drill was "slightly" deformed on the tip. he had the drill wide open, and was pushing with all he had. one spin of the drill to cool it off some, and yep ! it was in REVERSE ! i still jack him about that from time to time !
