Re: Which Proportioning valve for 4 wheel disc [Re: lostdog] #2510414
06/19/18 03:27 PM
06/19/18 03:27 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
Also I might add, after a little bit of reading, that I was wrong in stating ALL calipers were the same size...the rears still have 4 pistons, but they are a smaller diameter piston than the front.
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Which Proportioning valve for 4 wheel disc [Re: mopardude318] #2510632
06/20/18 01:24 AM
06/20/18 01:24 AM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
I think your setup will work just fine. I used a Wildwood proportioning valve with my 4 wheel disk setup. I'll leave it wide open to start and if I need more bias I'll adjust it. I would rather have it just in case as opposed to needing it and not have it.
