Torque convert wear
#2482654
04/14/18 05:42 PM
04/14/18 05:42 PM
Posts: 1,527 Michigan
GoDartGo
what causes this kind of wear on the converter? The flex plate was tight and the converter bolts were tight. I can feel about .010 on one side and nothing on the other.
Re: Torque convert wear
[Re: GoDartGo]
#2482656
04/14/18 05:47 PM
04/14/18 05:47 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Trans not exactly centered behind engine....you need to check and adjust bellhousing alignment.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: GoDartGo]
#2482694
04/14/18 07:03 PM
04/14/18 07:03 PM
GoDartGo
how much damage to the transmission internals would this cause? I have a spare case, just need to know if I should get another front pump? BTW, your right, the alinement hole on the trans are not good. thanks.
[Re: GoDartGo]
#2482750
04/14/18 09:55 PM
04/14/18 09:55 PM
Posts: 3,069 Michigan
A727Tflite
Wear on one side of the impeller is due to "flagpole" - the impeller is not perfectly perpendicular to the converter' lug plane.
A trans that does not share the same centerline as that of the crank would cause wear all the way around the impeller.
The other possibility - when the converter was installed the pilot was not buried in to the crank pocket when tightening the converter bolts.
[Re: GoDartGo]
#2482805
04/14/18 11:50 PM
04/14/18 11:50 PM
A727Tflite
A good converter shop would have no problem doing that - it would have to be cut at the large closure weld - then the impeller hub would have to removed at the weld and a new one installed then the impeller assembly welded back on to the front cover assembly. Local shops here get about $100 - $125 for all that.
What city are you in ?
[Re: GoDartGo]
#2483078
04/15/18 02:12 PM
04/15/18 02:12 PM
GoDartGo
I'm south of Battle Creek. I noticed one of the holes in the transmission case looked somewhat not so round, like the alinement pin had been forced. Both pins are in the block.
[Re: GoDartGo]
#2483217
04/15/18 06:56 PM
04/15/18 06:56 PM
Posts: 25,743 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Also, the hub could be out-of-round.
[Re: GoDartGo]
#2483286
04/15/18 09:13 PM
04/15/18 09:13 PM
A727Tflite
On an auto trans - the same way as you are supposed to on a manual trans bellhousing. A little harder to get in there but take your empty trans case and bolt it to the engine.
Take a magnetic dial indicator assembly and attach it to the cramkshaft.
The indicator proble should touch the OD of the pump bore - that checks bore runout. The indicator probe should then touch the gasket face of the pump bore - that's face runout.
Spin the crank to get TIR ( total indicator runout ).
Look in a service manual for the procedure - and I think it was also called out in the old Direct Connection manuals.
As long as you have two good dowels in the engine and the trans case bores for those dowels are round and not egg-shaped you are normally good. I can't recall ever having a need to install offset dowels like we did on manual transmissions. The flexplate is more forgiving than the flywheel. Plus the converter internals are forgiving too.
When you add pump bushing to converter clearances, internal converter clearances and the flexplate flexibility that provides more flexibility than the manual trans stack up.
[Re: GoDartGo]
#2483332
04/15/18 10:17 PM
04/15/18 10:17 PM
A727Tflite
Another observation is that once the trans is bolted in place you should be able to pull the converter in to the back of the crank without much effort. Some rotating clockwise and back while pulling g it forward should enable you to get the drive lugs close to the flexplate. Install your first bolt finger tight then rotate and install the next on and in until they are all installed.
Don't install the first bolt and go to torque - install the next three.
Before installing the trans converter assembly lightly coat the crank pocket where the converter pilots - this also allows the converter to slide in to place without much effort.
Don't forget to take the flexplate and lay it on the converter to make sure you have the offset lug located - then put a paint mark there - this way you install the bolts the first time and they all line up.
[Re: A727Tflite]
#2483448
04/16/18 02:53 AM
04/16/18 02:53 AM
Posts: 43,116 Bend,OR USA
Cab_Burge
Before installing the trans converter assembly lightly coat the crank pocket where the converter pilots - this also allows the crank to slide in to place without much effort.
Don't forget to take the flexplate and lay it on the converter to make sure you have the offset lug located - then put a paint mark there - this way you install the bolts the first time and they all line up. I use to use some bright paint to mark one ear on the flex plate and on the converter before taking them apart I never greased the hubs but that is a good idea
