Running engine on stand #2481699
04/12/18 04:00 PM
04/12/18 04:00 PM
Ottawa, ontario
dd340 Offline OP
dd340  Offline OP
Ottawa, ontario
What do I need to run my 340 on a stand before installing it in the car. I took it out a couple of years ago and put on new gaskets etc and I want to run it first before putting it back in to make sure no leaks etc. What is the simplest way to make this happen?
Re: Running engine on stand [Re: dd340] #2481751
04/12/18 05:45 PM
04/12/18 05:45 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
You are going to need a flywheel and a bell housing to mount your starter so you can start it. You don't want it to overheat so you need a way to cool it. I have started and run engines that were sitting on the floor. The only thing wrong with that is you can't run them very long that way. I suppose you could run a garden hose into the thermostat housing.
Re: Running engine on stand [Re: dd340] #2481797
04/12/18 07:41 PM
04/12/18 07:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Running engine on stand [Re: John_Kunkel] #2481806
04/12/18 08:03 PM
04/12/18 08:03 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
I made a run stand out of the front frame of an old class C motorhome. Hmm, I wonder if I should sell it.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Running engine on stand [Re: amxautox] #2481839
04/12/18 09:34 PM
04/12/18 09:34 PM
Ottawa, ontario
dd340 Offline OP
dd340  Offline OP
Ottawa, ontario
I’m wondering about wiring up the coil, starter, ignition box etc. Any tips on that?
Re: Running engine on stand [Re: dd340] #2481863
04/12/18 10:33 PM
04/12/18 10:33 PM
amxautox Offline
amxautox  Offline
Have a board that the coil, dual and/or single resister, ecu, switch with relay, installed on, and they are wired all the time. Just run a long wire from coil center to dist. center tower. Have a bypass circuit to bypass the ecu if your dist. is a points dist., or if you plan on using a points dist. someday.
Then all you need is the ground, and fuel line. The starter is wired the same as in car with the battery close by the starter.
Tom
author unknown
Re: Running engine on stand [Re: dd340] #2481902
04/12/18 11:25 PM
04/12/18 11:25 PM
there was a thread on his a week or so ago & someone posted a tailor made stand that can be purchased (online iirc) that was cheap that you could add more to it for a transmission in the rear & a radiator in the front. for a new eng breakin you would want to be able to load the eng to seat the rings but for your deal I'd get some angle iron & your chop saw & fab one up & bolt it together then have your welder weld it. A flat panel in the front to mount some gauges/switches etc. the MP basic race car wiring schematic might be in the archives.
Re: Running engine on stand [Re: RapidRobert] #2481913
04/12/18 11:49 PM
04/12/18 11:49 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Made my own out of a small utility trailer, still has wheels and trailer tongue so I can tow it around.
Re: Running engine on stand [Re: GODSCOUNTRY340] #2481969
04/13/18 01:42 AM
04/13/18 01:42 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Running engine on stand [Re: pittsburghracer] #2482064
04/13/18 11:03 AM
04/13/18 11:03 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
the one I like is the one that mounts on the cherry picker,
post #2449306 in the link pittsburg posted
