Re: Air conditioning compressor ideas [Re: hemi68charger] #2481539
04/12/18 11:29 AM
04/12/18 11:29 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Why do they run the alternator off the a/c compressor instead of shimming it and using a crank pulley with an extra groove so it gets its own belt?
Re: Air conditioning compressor ideas [Re: hemi68charger] #2481707
04/12/18 04:20 PM
04/12/18 04:20 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
They were probably trying to keep everything tight. I didn’t like the way they routed the belts because there wasn’t a lot of contact on the pulleys. Jcb426 or some member showed me how rerouting the belts would work better. Here are some better pics. I had to find the right waterpump pulley from a friend that had a hoard of pulleys to make it work.
DEE266E3-1CD9-48C5-B524-D7BEEB10FC31.jpegF907AE90-1873-4D3B-9108-BA2E6A1C335A.jpegED51BF91-16A0-4F82-AAA1-63B682F5FE12.jpeg
Re: Air conditioning compressor ideas [Re: rapom] #2482482
04/14/18 11:00 AM
04/14/18 11:00 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Originally Posted By rapom
I did what jbc426 did and bought the bouchillon low mount kit and rerouted the belts and have had no problems going on 6 years now. I even ran a gm based powermaster alt. which works nicely with the kit.
I dig your setup... If you don't mind, might reach out to you later once I get the Road Runner and start tinkering with it.. I will be putting the six pack set up on the car with the Fresh-Air hood set, so I like the compressor hidden so the top of the engine compartment isn't so cluttered....
Oh, I see you're a golf course Super? I remember my high school and post-high school days working ground maintenance... Pretty cool job from the traps to the fairway mowing... But, knew I needed to go to college eventually.. But, had to do the Air Force first.. Worked on a top-100 Nicklaus course in West Palm Beach....
Troy
Houston Mopar Connection Club
Re: Air conditioning compressor ideas [Re: hemi68charger] #2482981
04/15/18 11:46 AM
04/15/18 11:46 AM
poplar bluff mo.
toplescuda Online content
I Whine
toplescuda  Online Content
I Whine
poplar bluff mo.
That ultra low setup. Can be had v belt? Offer just the bracket/s to mount the pump?
Thanks in advance
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Air conditioning compressor ideas [Re: hemi68charger] #2483076
04/15/18 02:10 PM
04/15/18 02:10 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
yes I can sell just the brackets. but you'd lose out on all the modern accessories as well as the belt tensioner.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Air conditioning compressor ideas [Re: hemi68charger] #2483134
04/15/18 04:20 PM
04/15/18 04:20 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
I don't want the modern accessories or belt tensioner. Just looking for a mounting bracket...depending on what just that alone would cost
1971 charger
Re: Air conditioning compressor ideas [Re: hemi68charger] #2483747
04/16/18 05:55 PM
04/16/18 05:55 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i'd sell just the brackets. won't have anyway to adjust the belt tension. we would have to design that in and modify the brackets so that at least something is slotted.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Air conditioning compressor ideas [Re: hemi68charger] #2484062
04/17/18 08:49 AM
04/17/18 08:49 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
No problem, I have better pictures on another computer that I can get to you if needed. I’m still working at golf courses but only part time now. Enjoy every minute of it.
Re: Air conditioning compressor ideas [Re: hemi68charger] #2484318
04/17/18 06:28 PM
04/17/18 06:28 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Oh. I did not know the bracket it's self did not have a slot for and kind of adjustment. Guiess I was thinking more of how a alt. Would be and adjusted
1971 charger
