Re: Neutral safety switch with Ford starter solenoid?
[Re: AndyF]
#2480194
04/09/18 09:55 PM
04/09/18 09:55 PM
dartman366
Mt. Vernon, Ohio
iirc the older fords used a switch in the steering column for the neutral saftey , not sure how the newer ones did it, I know they had a one post and also a two post solenoid.
[Re: AndyF]
#2480210
04/09/18 10:28 PM
04/09/18 10:28 PM
Posts: 12,318 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
There are 2 styles of these solenoids.
A 3 pin, 2 large, 1 small, - the two large are the high amp studs to run the starter. These types are typically grounded through the case to whatever it's bolted to. They are engaged by putting 12v to the small terminal, usually from the starter switch, through a neutral safety switch to the solenoid.
A 4 pin, 2 large, 2 small. The large studs function the same. One small stud is for 12v to energize the solenoid, usually a single wire from the start switch. The other small stud provides the ground for the solenoid windings. Usually run through the neutral switch to a ground. This provides ground for the solenoid only when in P or N. This is the one I prefer. It's simple and uncomplicated to wire. And doesn't rely on being grounded through it's mounting. This is also how the factory starter relays worked and are best if using the Torqueflite NS switch.
There are also 4 pin solenoids that provide a 12v circuit for the ignition when the starter is engaged. These are usually grounded through the case as well.
A circuit diagram that usually comes with it or an ohm meter can be used to identify these switches. The counter guy won't know how unless he's sharp.
[Re: AndyF]
#2480224
04/09/18 10:41 PM
04/09/18 10:41 PM
Posts: 8,082 Tulsa OK
Bad340fish
Tulsa OK
I use a starter relay from an early 80s Jeep CJ. It looks just like a ford solenoid but it has a pin that has to be grounded to work, it works great with the stock neutral safety switch. I have mine mounted in the trunk by the battery. The post that needs grounded is on the bottom side, not visible in this picture.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2480229
04/09/18 10:50 PM
04/09/18 10:50 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have mine mounted in the trunk by the battery. Mine goes up front in the firewall area near the starter, typically inside the car. Only need to run one 12v cable up from the back.
[Re: AndyF]
#2480230
04/09/18 10:50 PM
04/09/18 10:50 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
As CMcAllister wrote, the 4 lug solenoid with the isolated ground for the acivation coil is the one you should have to use the factory ns switch. It can be tricky to get the correct one based solely on there being 4 terminals as stated. That style solenoid was used on a whole lot of generic equipment. Most used the 12v bypass for ignition, so be aware of that.
[Re: AndyF]
#2480242
04/09/18 11:04 PM
04/09/18 11:04 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
And you can get solenoids that look the same, but are intended for intermittent or constant duty. Starters require intermittent style.
[Re: Bad340fish]
#2480292
04/10/18 12:36 AM
04/10/18 12:36 AM
Posts: 31,203 Oregon
AndyF
I use a Neutral safety switch from an early 80s Jeep CJ. It looks just like a ford solenoid but it has a pin that has to be grounded to work, it works great with the stock neutral safety switch. I have mine mounted in the trunk by the battery. The post that needs grounded is on the bottom side, not visible in this picture. Yeah I dug around a little bit and found that NAPA ST83 seems to be the one recommended. It is a AMC/Jeep unit and also used on a lot of boats. The lug on the back hooks up to the NSS and grounds the case in P or N. I'll order one of them and see how it works. Thanks for the help.
[Re: dvw]
#2480304
04/10/18 01:10 AM
04/10/18 01:10 AM
Posts: 2,123 CA
crackedback
CA
Add a relay. Starter crank wire to pin 85, neutral safety switch wire to pin 86. battery to pin 30, wire from pin 87 to ford solenoid control feed. That way the factory neutral safety switch controls the Ford solenoid power feed. Doug Agreed... well written. Had to do the same thing on a a friends demon with a ford relay/cut off/CD relay for charge line set up. The 86 to NSS controls the ground. Turn key all you want when in gear, relay won't work unless trans is in P/N.
