Change 833 side cover gasket with trans in car?
#2479570
04/08/18 07:10 PM
04/08/18 07:10 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Can you change the 833 side cover gasket with the trans in the truck/car? I'm having trouble with the used 833 trans I put in my truck shifting into reverse...with the reverse rod disconnected the side lever shifts into reverse by hand no problem. I tried to loosen the side cover bolts and tap the side cover up, but it appears someone used rtv on the side cover, as it wont budge. I think I need to remove the side cover to remove the rtv and put a new side cover gasket on..so the side cover can be adjusted, but was hoping I wouldn't have to remove trans to do so. Never messed with an 833 before....but read that the side cover can be a bear to reinstall.
Any tips, tricks, etc? Or do I need to drop the trans?
Re: Change 833 side cover gasket with trans in car?
[Re: Quicksilver440]
#2479638
04/08/18 09:53 PM
04/08/18 09:53 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Early model ball and detent cover is much easier than the later lever type cover IMHO. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: dragon slayer]
#2481438
04/12/18 02:10 AM
04/12/18 02:10 AM
Quicksilver440
Central Valley, CA.
I understand the logic of what your saying...makes sense. I guess im not sure how easy the levers should be to move. I can shift the reverse lever by hand...but im not sure i would consider it easy to shift by hand....thus why i was thinking maybe the side plate might need adjustment. Figured i might as well change the sideplate rod seals while i have it off...ordered some from brewers last night.
