69 Charger 440 power steering pulley question #2478498
04/06/18 09:26 PM
04/06/18 09:26 PM
New Jersey
69Chrgr Offline OP
69Chrgr  Offline OP
New Jersey
I believe I have the wrong pulley for my Federal power steering pum. For it to line up with the crank pulley, I would have to pull it half way off the shaft, I looked and looked to see if a B body has a different pulley than maybe a C body, or the one I have is a non AC pulley, and I have AC. I saw one one on ebay that possibly is the right one, because with the sideview pic, the flange for the puller isn't visible, and on mine it is, so I'm thinking it has the correct offset, can someone enlighten me on these pulley and the different offsets?
Duane
Re: 69 Charger 440 power steering pulley question [Re: 69Chrgr] #2478626
04/07/18 01:16 AM
04/07/18 01:16 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I believe '68s used Federal but '69 should be Saginaw shruggy
Re: 69 Charger 440 power steering pulley question [Re: 69Chrgr] #2482376
04/13/18 11:56 PM
04/13/18 11:56 PM
KS
68SportSatvert Offline
KS
I have several pumps with pulleys and will look to see if there is any difference
Re: 69 Charger 440 power steering pulley question [Re: 69Chrgr] #2482499
04/14/18 11:45 AM
04/14/18 11:45 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
If is any help, here is the '69 parts catalog pump listing. It refers to "slotted shaft" and "threaded shaft". I assume that is the Federal/Saginaw difference. Maybe someone here will know for sure.
As you probably know, B bodies are R and W models in the parts catalog.
beer
Re: 69 Charger 440 power steering pulley question [Re: moparfan53] #2482503
04/14/18 11:48 AM
04/14/18 11:48 AM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Here is the pulley listing. I cut off the top so I could enlarge it to be more readable. B bodies are the 4th and 5th column from the left.
Re: 69 Charger 440 power steering pulley question [Re: moparfan53] #2482522
04/14/18 12:09 PM
04/14/18 12:09 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
I was curious about which pump was which, so looked in the '69 FSM. It has an illustration that helps a lot.
