clutch problem on 68 rr #2478444
04/06/18 06:53 PM
04/06/18 06:53 PM
pa. greensburg
fpmopar Offline OP
fpmopar  Offline OP
pa. greensburg
Installed a new 11 inch flywheel new clutch assy. when clutch is pushed in all the way pressure plate fingers rub on springs in clutch disc. ? any ideas.
Re: clutch problem on 68 rr [Re: fpmopar] #2478456
04/06/18 07:27 PM
04/06/18 07:27 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Don't push it all the way in !!!
Re: clutch problem on 68 rr [Re: fpmopar] #2478457
04/06/18 07:28 PM
04/06/18 07:28 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
How much pedal free play is there - should be about 1".
Is the disk in the right way - its marked "flywheel side"
Re: clutch problem on 68 rr [Re: fpmopar] #2478460
04/06/18 07:34 PM
04/06/18 07:34 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Backoff the adjustment some.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: clutch problem on 68 rr [Re: fpmopar] #2478467
04/06/18 07:54 PM
04/06/18 07:54 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
sounds like the disk may be in backwards.
Re: clutch problem on 68 rr [Re: Stanton] #2478588
04/07/18 12:21 AM
04/07/18 12:21 AM
pa. greensburg
fpmopar Offline OP
fpmopar  Offline OP
pa. greensburg
have about an inch of free play
Re: clutch problem on 68 rr [Re: stumpy] #2478592
04/07/18 12:24 AM
04/07/18 12:24 AM
pa. greensburg
fpmopar Offline OP
fpmopar  Offline OP
pa. greensburg
the disc is in correctly could the fingers on pressure plate be out of adjustment?
Re: clutch problem on 68 rr [Re: fpmopar] #2478698
04/07/18 06:06 AM
04/07/18 06:06 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
The linkage is simply pushing the fingers too far in....back off the linkage some. Forget the inch, you need what works.
Take care,
Rick
Re: clutch problem on 68 rr [Re: fpmopar] #2478734
04/07/18 09:48 AM
04/07/18 09:48 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
NO, you need the inch. Any more free play and the overtop spring won't do its job and the pedal won't come all the way up.
Re: clutch problem on 68 rr [Re: fpmopar] #2478753
04/07/18 10:28 AM
04/07/18 10:28 AM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
Had a similar issue with a McCloud 11 inch clutch, Adjusted to about 1and 1/2 INCH FREE PLAY and have been driving for 5 years now No Issues. Just pulled 440 out and Clutch Plate looks Great !!
Not sure this will help you but worth a shot !
Re: clutch problem on 68 rr [Re: TOMRR] #2478825
04/07/18 01:26 PM
04/07/18 01:26 PM
New York
rarefish Online content
rarefish  Online Content
New York
Are you using a B&B clutch?
If so then I had pretty much the same problem with a low end street replacement clutch that I bought for my 69 340 Dart last fall. When I put the pedal near the floor I heard a scrapping noise.
Everyone said the disc in backwards or not adjusted correctly. What it turn out to be was that the pressure plate height was set too low when assembled at the factory.
When I bolted the pressure plate to the fly wheel with the disc in place. The clutch fingers over traveled and were already too close the the disc springs in the static assembly. So now when you push the clutch pedal down enough to release the clutch the fingers ended up coming into contact with the disc springs.
I took back out out the pressure plate and measured the height of the plate off of the cover mounting pads and compared it to the height of the old pressure plate that I had. I found that there was quite a difference.
Re: clutch problem on 68 rr [Re: fpmopar] #2478911
04/07/18 04:51 PM
04/07/18 04:51 PM
pa.
dan9 Offline
dan9  Offline
pa.
McCleod I purchased from Jamie Passon did the same thing. It seemed they had a design problem at one time. They sent a new kit and that solved the problem. I would contact the clutch manufacturer.
Re: clutch problem on 68 rr [Re: rarefish] #2479701
04/08/18 11:36 PM
04/08/18 11:36 PM
pa. greensburg
fpmopar Offline OP
fpmopar  Offline OP
pa. greensburg
I think that is my problem the fingers on the plate are not adjusted correctly. Can they be adjusted or just ger another plate?
Re: clutch problem on 68 rr [Re: rarefish] #2479704
04/08/18 11:38 PM
04/08/18 11:38 PM
pa. greensburg
fpmopar Offline OP
fpmopar  Offline OP
pa. greensburg
I am using a B&B plate.
Re: clutch problem on 68 rr [Re: fpmopar] #2479881
04/09/18 11:25 AM
04/09/18 11:25 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Not an adjustment you can do.
