Re: Ali G3 block from mopar
[Re: RylisPro]
#2490040
04/30/18 04:03 PM
04/30/18 04:03 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
That's Cool, Are you going to be able to sell Arrow/Prefix's Alum Manifold? or just the Drag Pak
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: RylisPro]
#2490058
04/30/18 04:54 PM
04/30/18 04:54 PM
Posts: 12,478 Kalispell Mt.
HotRodDave
Kalispell Mt.
Everything they sell! My goal is to make the Gen 3 Hemi swap more popular than the LS swap Thats a wonderful goal and all but it ain't gonna happen till we get a few key parts that are afordable like carb intakes and such. LS intakes start out under $300 shipped. Ignitions under $400. Headers for the most common swaps under $300. As awesome as the high quality high dollar stuff is it will never be as popular as some lower priced options for the vast majority of people.
[Re: fbs63]
#2490403
05/01/18 01:04 PM
05/01/18 01:04 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Hey fbs63, Prefix is still getting a parts and pricing list together and I'll get it sorted out on my website as soon as they send it to me. As for the blocks the one posted on their website is P5155507 with a finished bore 4.125 max bore 4.155. P5153898 with a finished bore 4.114 max bore 4.185 is also available. The new updated blocks that just came out are not currently available but I'll get more info of when they do. I'm going to base my next 426 engine off of one
[Re: RylisPro]
#2490463
05/01/18 02:43 PM
05/01/18 02:43 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Hey fbs63, Prefix is still getting a parts and pricing list together and I'll get it sorted out on my website as soon as they send it to me. As for the blocks the one posted on their website is P5155507 with a finished bore 4.125 max bore 4.155. P5153898 with a finished bore 4.114 max bore 4.185 is also available. The new updated blocks that just came out are not currently available but I'll get more info of when they do. I'm going to base my next 426 engine off of one The new updated blocks do you mean the one with the offset lifters? If so I'm interested in the info also! Thanks Matt
[Re: MattW]
#2490468
05/01/18 02:51 PM
05/01/18 02:51 PM
HotRodDave
Kalispell Mt.
Just use a P7 manifold. Matt Who sells an adapter for this and how much? Theyre certainly not going to bolt on with those different flange angles and deck heights...
[Re: RylisPro]
#2507703
06/12/18 10:02 PM
06/12/18 10:02 PM
MattW
Ontario Canada
Hey Matt, I'll ask about the offset lifter blocks as well. Any news?
[Re: RylisPro]
#2523253
07/17/18 08:36 PM
07/17/18 08:36 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Just got off the phone with Prefix and have some info to clarify with the Gen 3 Hemi aluminum blocks. 6.1 aluminum blocks are available and have been used in builds a little over 1000hp. These blocks are available through Prefix. 7.0 aluminum blocks are basically 6.1 blocks re-cast with additional reinforcements and "X" bracing on the blocks. Made primarily for the 2016 354 cid and 426 cid Drag Pack Challengers, most all have been already sold and Prefix cannot get them. 6.4 aluminum blocks are a new release from Mopar made for the Factory Stock drag racing series and have relocated oil pick ups and require different oil pans among other changes to accomodate for VVT options.They are so new that even Prefix is not able to get them but may be available through your local Mopar dealer.
[Re: A990]
#2523923
07/19/18 03:01 AM
07/19/18 03:01 AM
Posts: 2,432 NorCal
RylisPro
NorCal
I don't know the exact weight just that the 6.1 aluminum blocks are advertised as 100 lbs. lighter than the production cast iron 6.1 blocks. Not really apples to apples comparison, but when I swapped out my cast iron aluminum top end 340 with the current all-aluminum 426 Gen3 it was about 80lbs. less on the front end. Yes, the engine was very expensive but I am so happy that I got it. No issues with it whatsoever, has ran great for thousands of miles with no major issues, very responsive on a road course and best of all no leaks!
