Re: Seat belt questions
[Re: 440mopar]
#2477311
04/04/18 11:29 AM
04/04/18 11:29 AM
Posts: 3,524 Lansing, MI
70gtx440dana
Lansing, MI
Spacers, long bolts and washers are used at locations with more than one belt fastened to the floor. This would be in the two rear locations at the side of the trans hump. It would also be in the front on either side of the trans hump. Short bolts are used where there is only one belt attached.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 440mopar]
#2478266
04/06/18 12:05 PM
04/06/18 12:05 PM
Posts: 16,150 Mesa, Arizona
dart4forte
Mesa, Arizona
Thanks guys. Does anyone know about the retractor question I asked? I would really like to swap the belts from one retractor to the other but I don't want to risk ruining the plastic enclosures trying to get the belts out of them if it can't be done. What do you mean plastic enclosures? Are talking about the rubber boots?
Abe Lincoln
[Re: 440mopar]
#2478423
04/06/18 06:02 PM
04/06/18 06:02 PM
dart4forte
Mesa, Arizona
We use a heat gun or hair drier to soften them up a bit. Not too hot to distort them. They usually have two rivets that hold them to the metal. be carefull not to tear the rubber.
Abe Lincoln
[Re: LTLBEE]
#2478981
04/07/18 07:43 PM
04/07/18 07:43 PM
Posts: 101 S.E. WI
RichL1967
S.E. WI
How did you manage to sew them?
Common sense and caution are factors which cannot be built into any product. These must be supplied by the operator.
[Re: RichL1967]
#2478987
04/07/18 07:54 PM
04/07/18 07:54 PM
dart4forte
Mesa, Arizona
How did you manage to sew them? Our belts are sewn using an industrial sewing machine
Abe Lincoln
[Re: dart4forte]
#2479971
04/09/18 01:56 PM
04/09/18 01:56 PM
Posts: 732 USA
440mopar
USA
We use a heat gun or hair drier to soften them up a bit. Not too hot to distort them. They usually have two rivets that hold them to the metal. be carefull not to tear the rubber. Thanks. I will give it a try.
