Kirkey seats in a stock floor board e body #2472430
03/26/18 06:38 PM
03/26/18 06:38 PM
Big Western Pencilveinya
U
Uncle Barry Offline OP
U
Anybody? Just window shopping now. Would like to put a rollbar in my car soon and just curious if anyone has pictures and how they like them and if they worked with stock floor pans. Thanks all
Re: Kirkey seats in a stock floor board e body [Re: Uncle Barry] #2472459
03/26/18 07:46 PM
03/26/18 07:46 PM
AndyF Offline
AndyF  Offline
They will work but you'll need to fabricate brackets. I built a few different ones for my car and ended up using these.
Re: Kirkey seats in a stock floor board e body [Re: Uncle Barry] #2472658
03/27/18 10:04 AM
03/27/18 10:04 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
If you do install, make sure you at least put some type of metal on bottom side so the bolts don't pull thru the stock floor if something bad may happen
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Kirkey seats in a stock floor board e body [Re: Uncle Barry] #2472663
03/27/18 10:17 AM
03/27/18 10:17 AM
U
U
Thanks Andy and Bigdad. I appreciate the advice
Re: Kirkey seats in a stock floor board e body [Re: Uncle Barry] #2472780
03/27/18 02:45 PM
03/27/18 02:45 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
We made tubular mount in my car that tie into the factory seat holes & in addition to the frame connector/undercar bars & into the trans tunnel as well. Hard to tell but they are under there.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Kirkey seats in a stock floor board e body [Re: Uncle Barry] #2473184
03/28/18 07:35 AM
03/28/18 07:35 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Apologies for Hijacking here but where do you guys get the carbon fibre bar covers from?
TIA
Re: Kirkey seats in a stock floor board e body [Re: Uncle Barry] #2473205
03/28/18 09:58 AM
03/28/18 09:58 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Re: Kirkey seats in a stock floor board e body [Re: Uncle Barry] #2473259
03/28/18 12:24 PM
03/28/18 12:24 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I got a 73 Cuda and I'm looking at the same, I know mine will rest on the floor just to get head room. E-bodys don't have much height as the b-bodys (I think 2" less). Even my Duster seats are bolted directly to the floor, (poly type) just to get my head under the roll bar (6-1)
Been toying with some mounts but I like the looks of the side mounts shown above.
Remember, seats need to be attached adequately but it's the seat belts that holds you and the seat in place in the event of a wreck.
Re: Kirkey seats in a stock floor board e body [Re: bigdad] #2473333
03/28/18 02:52 PM
03/28/18 02:52 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Yep, Bickel is where I bought mine. I didn't really want to cover up all the blue but they do help keeping everything looking good after climbing in & out so much & the seat belts smacking off off the bars.
Re: Kirkey seats in a stock floor board e body [Re: Uncle Barry] #2473352
03/28/18 03:18 PM
03/28/18 03:18 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
One thing to get right is the position of the seat, also the height and lay back. Race car or street car once their bolted down you don't want to be uncomfortable . Block it up with 2 x 4 "s or anything to get it setting right then measure , drill and bolt it down.
Re: Kirkey seats in a stock floor board e body [Re: rowin4] #2473388
03/28/18 04:49 PM
03/28/18 04:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm glad you said that.. a lot of guys dont add
in the lay back part and its never comfortable
wave
Re: Kirkey seats in a stock floor board e body [Re: Uncle Barry] #2473392
03/28/18 04:55 PM
03/28/18 04:55 PM
AndyF Offline
AndyF  Offline
I have an extra set of the brackets I made for my car if you are interested. You'll need to fabricate the rails for the floor, I just have the side brackets.
Re: Kirkey seats in a stock floor board e body [Re: cudaman1969] #2473486
03/28/18 07:51 PM
03/28/18 07:51 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
I disagree with that somewhat, a seat belt holds you against the seat, it the seat moves away from the belt, the belt goes limp, defeating the belts purpose. The seat needs to be secured to incur all, if not more forces then the seat belts, in regards to anchorages, to allow both to do their job together. twocents
Re: Kirkey seats in a stock floor board e body [Re: jcc] #2473671
03/29/18 02:03 AM
03/29/18 02:03 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Belts and seat are for frontal and somewhat side impacts. How would the seat move in a frontal impact if belts a drawn tight? It would tighten up against the belts. Rear impact, belts maybe not, seat could if the persons mass didn't rip it out of the mounts. Anyway go online and read up on the aviation study's.
Re: Kirkey seats in a stock floor board e body [Re: cudaman1969] #2473774
03/29/18 12:06 PM
03/29/18 12:06 PM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Do not assume accidents are predictable nor likely just frontal, nor just a single impact. The issue is once a seat moves ( likely does not rebound) in any direction that loosens the belts, the belts serve little use in any additional impacts from any direction. I think comparing the intended purpose of a seat belt in a thin skinned alum tube that can reach mid 3 digit speeds impacts with the ground to a steel purpose designed forimpact cage at barely 3 digit speeds with an occupant wearing a rated helmet is not overly useful. twocents
Re: Kirkey seats in a stock floor board e body [Re: Uncle Barry] #2473834
03/29/18 02:38 PM
03/29/18 02:38 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Opinions are like butts, we all have one.
