wilwood brakes ? #247244
03/08/09 07:21 PM
03/08/09 07:21 PM
pitts. pa.
hoss Offline OP
hoss  Offline OP
pitts. pa.
I just purchased a set of wilwood brakes off of ebay.Part # 140-2726. They will be going on my 67 belvedere that has factory drums. I already got the corrct spindles to fit the brakes. Could I just run a stock disk brake master cylinder with the wilwood brakes ? And can I run thru the stock proportioning valve? Thanks Todd
Re: wilwood brakes ? [Re: hoss] #247245
03/08/09 07:36 PM
03/08/09 07:36 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I would use a late model aluminum Mopar M/Cyl with adapter setup.You can use the stock prop valve.This is what I did when I put Wilwoods on my Demon a few years ago.
Nautilus Racing-
