426 Hemi Rocker stands, Original or Aluminum? #2471821
03/25/18 02:56 PM
03/25/18 02:56 PM
USA
Suregrip391 Offline OP
USA
If one were to build a stock 426 or even a stroked 472 Hemi for the Street using a cast iron block and Mopar Performance aluminum heads, is there any preference to using the cast iron original stands vs. using aftermarket aluminum rocker stands on the aluminum heads?
The reason I ask, I have a couple sets of both and wanted to sell a set. Not sure which to let go. Thanks.
Re: 426 Hemi Rocker stands, Original or Aluminum? [Re: Suregrip391] #2471917
03/25/18 05:57 PM
03/25/18 05:57 PM
Cab_Burge Online work
Cab_Burge  Online Work
The OEM cast steel or ductile iron stands are a lot stronger than any of the after market aluminum stands currently out there for stock heads work
Street and strip motors will live forever with the stock stands up
I have 5 or 6 broken(cracked) aluminum race stands that are collecting dust, I've never seen any stock cast stands broken from normal use, not on a blown fuel motor that hydraulic, in other words work
Re: 426 Hemi Rocker stands, Original or Aluminum? [Re: Suregrip391] #2471940
03/25/18 06:58 PM
03/25/18 06:58 PM
New York
polyspheric Offline
polyspheric  Offline
New York
X2 - the aluminum stuff is highly stressed, it can't be made thicker to compensate for the reduced stiffness (steel vs. aluminum bending resistance = 3:1).
Boffin Emeritus
Re: 426 Hemi Rocker stands, Original or Aluminum? [Re: Suregrip391] #2471958
03/25/18 08:27 PM
03/25/18 08:27 PM
USA
USA
Good to know, thank you both very much.
Re: 426 Hemi Rocker stands, Original or Aluminum? [Re: Suregrip391] #2472204
03/26/18 10:51 AM
03/26/18 10:51 AM
an8sec70cuda Offline
I have KB aluminum stands on my 572" hemi that have been used since 2006 w/ no trouble at all. 276/284 solid roller, 220 psi seat, 600+ psi open pressure.
As heavy as everything is for a hemi, I'd use the aluminum stands as long as they're decent quality parts.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 426 Hemi Rocker stands, Original or Aluminum? [Re: Suregrip391] #2472240
03/26/18 12:09 PM
03/26/18 12:09 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
The anodized aluminum stands are much sexier looking. That's all I need to know.
2011 Drag Pak Challenger
Re: 426 Hemi Rocker stands, Original or Aluminum? [Re: Suregrip391] #2472263
03/26/18 01:08 PM
03/26/18 01:08 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I'm always looking for ways to make my car lighter. The aluminum stands are an easy and obvious way to do so. So far, I've never had a problem with them.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: 426 Hemi Rocker stands, Original or Aluminum? [Re: an8sec70cuda] #2472329
03/26/18 03:23 PM
03/26/18 03:23 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Me too! When i went to aluminum heads & rocker stands the weight saving was close to 90 lbs.With everything else I did the total loss was 200 lbs!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 426 Hemi Rocker stands, Original or Aluminum? [Re: hemi-itis] #2472335
03/26/18 03:38 PM
03/26/18 03:38 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I think the Barton is about as good looking as you can get - but it is heavy because of the bed plate
Re: 426 Hemi Rocker stands, Original or Aluminum? [Re: DoubleD] #2472389
03/26/18 05:36 PM
03/26/18 05:36 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I agree on the Barton's. I am not that concerned with weight. My car is still a street car, no lightweight anyway being all steel, all glass & full interior.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 426 Hemi Rocker stands, Original or Aluminum? [Re: 6PKRTSE] #2472431
03/26/18 06:40 PM
03/26/18 06:40 PM
If your wanting to rev your old 426 type Hemiroid motor up past 7000 RPM the Barton and other single rocker per shaft systems are the best way to go up If you want to keep it under 7500 RPM the stock type systems work well for that application, with the proper parts work devil whistling
Re: 426 Hemi Rocker stands, Original or Aluminum? [Re: Suregrip391] #2473182
03/28/18 07:25 AM
03/28/18 07:25 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
It would be nice if Ray Barton offered a lighter version of his rocker setup made from 7075-T651 Aluminum.(For the light weight guys)
Re: 426 Hemi Rocker stands, Original or Aluminum? [Re: Cab_Burge] #2473342
03/28/18 03:01 PM
03/28/18 03:01 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Mine Petered out at 7900 on motor on the dyno with my little ole street nitrous cam.
Re: 426 Hemi Rocker stands, Original or Aluminum? [Re: 6PKRTSE] #2473670
03/29/18 01:57 AM
03/29/18 01:57 AM
How did it peter out, did it quit gaining power or did a part fail? work
I remember when Don Purdhome (SP?) switch from a stock set of pushrods on his 1968 top Fuel dragster at Orange County testing one night to a set of B&B single tapered pushrods and gained 500 RPM, went from 7000 RPM to 7500 RPM boogie
426 Hemiroid motors and their stinking stock valve train can be a real pain to make work well for higher than 7000 RPM shruggy
Re: 426 Hemi Rocker stands, Original or Aluminum? [Re: Suregrip391] #2473788
03/29/18 12:36 PM
03/29/18 12:36 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
quit gaining power
