MSD soft touch rev control #2469883
03/21/18 07:01 PM
03/21/18 07:01 PM
High Plains of South Dakota
O
olwhite64 Offline OP
O
I'd like to put some kind of 2 step on my bracket car in order to launch it off of the transbrake.
Right now, I run stock Chrysler ignition. Can I wire up an MSD soft touch rev control (#8728) to the transbrake button (with a 3,000 rpm chip) or am I going to have to buy a whole new ignition system with an integrated 2 step?
Thanks for the help!
Re: MSD soft touch rev control [Re: olwhite64] #2469899
03/21/18 07:20 PM
03/21/18 07:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes you can.. I ran one when I first started
out in my car.. I ran the Gold box but they
all work
wave
Re: MSD soft touch rev control [Re: MR_P_BODY] #2470261
03/22/18 10:26 AM
03/22/18 10:26 AM
O
O
Thanks for the advice -
Would you just tie the power wire into the switched side of the transbrake switch or would you use a relay?
Re: MSD soft touch rev control [Re: olwhite64] #2470299
03/22/18 11:57 AM
03/22/18 11:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I wired it up per their diagram.. worked great
EDIT
After a couple of years I changed the 2 step and
went to a 3 step.. used their diagram again on the
3 step
wave
Re: MSD soft touch rev control [Re: MR_P_BODY] #2470872
03/23/18 11:00 AM
03/23/18 11:00 AM
O
O
Thanks Mr. P-body!
