Re: When it rains, it pours
[Re: J_BODY]
#2469681
03/21/18 01:22 PM
03/21/18 01:22 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
back her down to a mid 10 combo and a lot of those problems will go away! Yaaaaaa right. That was kind of funny.
[Re: dvw]
#2471730
03/25/18 12:13 PM
03/25/18 12:13 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
How many passes on that beast??? Where was the crack in the frame?? Was it from going up or on the landing ![work work](/ubbthreads/images/graemlins/custom/work.gif) Maybe add'l bracing could prolong that.Your regular PM program shows the benefit!!Good luck this season.
[Re: dvw]
#2471782
03/25/18 01:39 PM
03/25/18 01:39 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
No rest for the fast guys, Doug..... I read posts like this and think an 11 second street / strip ride just may be the right place to be. Good luck! I’m sure you’ll have it back together “lickety split”! 😉
[Re: hemi-itis]
#2472043
03/25/18 11:12 PM
03/25/18 11:12 PM
Posts: 9,886 MI, usa
dvw
MI, usa
How many passes on that beast??? Where was the crack in the frame?? Was it from going up or on the landing ![work work](/ubbthreads/images/graemlins/custom/work.gif) Maybe add'l bracing could prolong that.Your regular PM program shows the benefit!!Good luck this season. 500 passes. The frame crack was right in front of the left rear K frame bolt. Must have had a mouse nest in there at one time. Pretty thin, but only a small area. It's all cut out. i'll fab a replacement part tomorrow. Doug
