Re: Pinion contact thoughts.
[Re: Scamp408]
#2475079
03/31/18 09:28 PM
03/31/18 09:28 PM
Posts: 11,531 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Some of these things fall together nice. Some can be a PITA. Looking at all those pictures, I think I would throw 083 or 084 in it, open the backlash to 10 or 11, maybe 12 if it likes it, and live with it.
[Re: Scamp408]
#2475150
04/01/18 12:59 AM
04/01/18 12:59 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I see that. That last set of pics looks like it's a little deep on the drive side and not too bad on the coast. That's why I was thinking - reduce the shim pack a few thou and put it together. I would still open the backlash some. Are these new? Street car? Are there numbers inked on them identifying them as a matched set? Did they come from a mail order or where?
[Re: Scamp408]
#2475474
04/01/18 05:13 PM
04/01/18 05:13 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Well, that matters. Used stuff is a pain. I was told long ago that when setting up a used set of gears, look at the coast side and ignore the drive side, since the drive side gets all of the wear. It is advice that has worked well for me. Based on that, the first set of photos with a .090 shim has the best coast pattern. Put that in with 8-10 BL and send it.
