things i am looking for the Valiant project
#2466870
03/15/18 01:01 PM
03/15/18 01:01 PM
Posts: 34,942 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Been using my google but .. 1st time I'm dipping my toes into the small block pool Does anyone provide a fairly complete fastener kit (ARP) Gardner-Wescott both are fairly clumsy websites For Small block Mopar so I don't have to run to store multiple times I'm off the beaten path Next would be suggestion on which Valve covers will clear Harlan sharp rockers Which distributor does everyone prefer ? I have most of the pieces bought for the engine, trans is all done will need converter will have to see what motor does on dyno to pick that out. what about elec water pump, anyone try this ? http://www.jegs.com/i/Moroso/710/63565/10002/-1
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: things i am looking for the Valiant project
[Re: bigdad]
#2466899
03/15/18 01:55 PM
03/15/18 01:55 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
thanks , forgot about them
[Re: NoFrills]
#2467109
03/15/18 10:18 PM
03/15/18 10:18 PM
dartman366
Mt. Vernon, Ohio
I had the older version of that same pump and worked flawless for 10+ years, any of the smallblock VC's seem to work well except some of the fabricated ones with the bolt tubes welded in, some of those didn't fit so well if the tube angle was off, Big block had the same issue.
[Re: bigdad]
#2468325
03/18/18 09:54 PM
03/18/18 09:54 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I'm planning some creative space enlargement for radiator
[Re: dartman366]
#2468399
03/19/18 12:10 AM
03/19/18 12:10 AM
Posts: 4,700 Wichita
GY3
Wichita
Do you still have the silver truck?
[Re: GY3]
#2468496
03/19/18 10:54 AM
03/19/18 10:54 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Do you still have the silver truck? Yes
[Re: bigdad]
#2468498
03/19/18 10:57 AM
03/19/18 10:57 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Will need windshield and gasket , had two glass guys say they were going to get me them and both times .. no action
[Re: bigdad]
#2468754
03/19/18 08:28 PM
03/19/18 08:28 PM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Will need windshield and gasket , had two glass guys say they were going to get me them and both times .. no action The truck or the wagon? Kevin
[Re: bigdad]
#2468840
03/19/18 11:22 PM
03/19/18 11:22 PM
Twostick
Still wishing...
Still wishing...
Do you have the NAGS number for it? I have a really good glass guy that I can at least confirm availability thru. Kevin
