things i am looking for the Valiant project #2466870
03/15/18 01:01 PM
03/15/18 01:01 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Been using my google but ..
1st time I'm dipping my toes into the small block pool
Does anyone provide a fairly complete fastener kit (ARP) Gardner-Wescott both are fairly clumsy websites
For Small block Mopar so I don't have to run to store multiple times I'm off the beaten path
Next would be suggestion on which Valve covers will clear Harlan sharp rockers
Which distributor does everyone prefer ?
I have most of the pieces bought for the engine, trans is all done will need converter will have to see what motor does on dyno to pick that out.
what about elec water pump, anyone try this ?
http://www.jegs.com/i/Moroso/710/63565/10002/-1
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: things i am looking for the Valiant project [Re: bigdad] #2466888
03/15/18 01:33 PM
03/15/18 01:33 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Mancini has the fastener kits. I bought a stainless ARP kit from them for my big block build.
http://www.manciniracing.com/enacfaskit.html
Re: things i am looking for the Valiant project [Re: bigdad] #2466899
03/15/18 01:55 PM
03/15/18 01:55 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
thanks , forgot about them
Re: things i am looking for the Valiant project [Re: bigdad] #2466904
03/15/18 02:12 PM
03/15/18 02:12 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Using the MP cast covers on my Batten W2s with HS rockers, .630 lift, tall valves & springs. Did require clearancing at Strip Dominator intake runners.
Using the old-school Moroso belt pump, reckon the new style is likely better flow but don't know; new style's certainly cleaner in appearance. Drag car, never tried it on the street, but it's been fine on long return roads after a pass.
Distributor is the car's original electronic cable-tach deal, feeds an MSD, still good to 8000 RPM.
Re: things i am looking for the Valiant project [Re: topside] #2466980
03/15/18 05:21 PM
03/15/18 05:21 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
I have that water pump on my car. It was on it when I bought it. Seams to move a lot of water fast. Between it and a electric fan cools fast between rounds.
Re: things i am looking for the Valiant project [Re: NoFrills] #2467109
03/15/18 10:18 PM
03/15/18 10:18 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I had the older version of that same pump and worked flawless for 10+ years, any of the smallblock VC's seem to work well except some of the fabricated ones with the bolt tubes welded in, some of those didn't fit so well if the tube angle was off, Big block had the same issue.
Re: things i am looking for the Valiant project [Re: bigdad] #2467117
03/15/18 10:33 PM
03/15/18 10:33 PM
New England
Tech Instructor Offline
New England
Bigdad how about some recent pics of the Wagon
Re: things i am looking for the Valiant project [Re: Tech Instructor] #2467255
03/16/18 10:57 AM
03/16/18 10:57 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
here it is
Re: things i am looking for the Valiant project [Re: bigdad] #2467262
03/16/18 11:21 AM
03/16/18 11:21 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
While I am sure there is nothing wrong with the Moroso pump, I am a big Meziere fan. High quality pumps, exceptionally good customer service, and just all around good folks.
Re: things i am looking for the Valiant project [Re: bigdad] #2467271
03/16/18 11:54 AM
03/16/18 11:54 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
"IF"... I had to do it again, I'd go the Meziere remote pump. Always seems to be lack-o-room up front on small block/small engine bay combos. Being you're planning on street driving that would give you ample room for a good radiator and fan set up.
Re: things i am looking for the Valiant project [Re: bigdad] #2468325
03/18/18 09:54 PM
03/18/18 09:54 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I'm planning some creative space enlargement for radiator
Re: things i am looking for the Valiant project [Re: bigdad] #2468334
03/18/18 10:20 PM
03/18/18 10:20 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Originally Posted By bigdad
here it is
I like it!! up
Re: things i am looking for the Valiant project [Re: dartman366] #2468399
03/19/18 12:10 AM
03/19/18 12:10 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Do you still have the silver truck?
'63 Dodge 330
11.19 @ 121 mph
Re: things i am looking for the Valiant project [Re: GY3] #2468496
03/19/18 10:54 AM
03/19/18 10:54 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Yes
Re: things i am looking for the Valiant project [Re: bigdad] #2468498
03/19/18 10:57 AM
03/19/18 10:57 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Will need windshield and gasket , had two glass guys say they were going to get me them and both times .. no action
Re: things i am looking for the Valiant project [Re: bigdad] #2468545
03/19/18 12:45 PM
03/19/18 12:45 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Art
Re: things i am looking for the Valiant project [Re: bigdad] #2468696
03/19/18 06:37 PM
03/19/18 06:37 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Dig it!! up up
Re: things i am looking for the Valiant project [Re: bigdad] #2468754
03/19/18 08:28 PM
03/19/18 08:28 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The truck or the wagon?
Kevin
Re: things i am looking for the Valiant project [Re: bigdad] #2468788
03/19/18 09:44 PM
03/19/18 09:44 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
The wagon
Re: things i am looking for the Valiant project [Re: bigdad] #2468840
03/19/18 11:22 PM
03/19/18 11:22 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The wagon
Do you have the NAGS number for it? I have a really good glass guy that I can at least confirm availability thru.
Kevin
