Page 3 of 3 1 2 3
Re: Which street drag tires? [Re: ScottSmith_Harms] #2464799
03/11/18 04:07 PM
03/11/18 04:07 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
Originally Posted By ScottSmith_Harms
I have driven hundreds and hundreds of street miles on QTP’s nice tires
The 28 by 11.5( 28 by 10 wide) fits nicely on a Demon/ Duster with correct backspace wheel.
What offset/backspace are your wheels? Stock axle width?
X2 popcorn
Plymouth Makes It!
Re: Which street drag tires? [Re: hemi-itis] #2464923
03/11/18 09:00 PM
03/11/18 09:00 PM
Originally Posted By hemi-itis
I am curious if ANY of you with over 500 HP can hook from a dead stop???
I have ET Street R's bias and I cant hook down low whatsoever.I av roll out in 1st and short shift 2nd then roll into it hard so 2/3s of the way through 2nd I'm at WOT then click high and stay hooked,,,most of the time.
Also use 31 X 16.5's. Ay the track I use 10.5w M\T and they work very good drive shruggy
My 517 C.I. six pack piump gas motor made over 600 HP to the flywheel and 545HP to the rear tires on a dyno jet chassis dyno here in Bend several years back, shruggy
The M/T 13x31x15 ET street bias tires would almost dead hook at 9.0 lbs. on 10 inch wide wheels on my old Duster on the street, 1/2 to 3 turns max devil up weighing 3450 Lbs. total ready to race with 50.7 % weight on the front tires shruggy I raced it with all three sets of tires on the car, the bias plies 13x31x15 ET street tires where the slowest ET and MPH at the track and the 315x60x15 M/T ET Street Radials ET and MPH where almost identical to the 10.5x31x15 M/T drag race slicks, the car would cross the finish line at 6500 RPM at 134.+ MPH with the slicks and cross at 7000 RPM with the ET Street Radials at almost the same MPH and ET confused shruggy I never drove that car with slicks on the road so no input about that shruggy
I do like the M/T ET Street bias ply tires better on the street with decent HP compared to the M/T ET Street radials I used shruggy
Re: Which street drag tires? [Re: B3422W5] #2465025
03/12/18 12:15 AM
03/12/18 12:15 AM
Taylor, Michigan
1BadLiLCharger Offline
Taylor, Michigan
Originally Posted By B3422W5
Good to see you posting Pat
Thanks, Don. Retired now, may pop in more from time to time. But ya never know.
Re: Which street drag tires? [Re: RoadRunnerLuva] #2465149
03/12/18 12:06 PM
03/12/18 12:06 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
X2 popcorn
28 by 11.5 QTP..... 15 by 10 wheel with 4.5 backspace. This on a 70 Duster, super stock springs in stock location
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Which street drag tires? [Re: ScottSmith_Harms] #2465172
03/12/18 12:51 PM
03/12/18 12:51 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
67 barracuda. Dana narrowed 4"/side, minnie tub, 15x10-3.5bs with a 28x14.50x15 QTP. Biggest tire that will fit in there. Just to give an idea.
Re: Which street drag tires? [Re: mopar dave] #2465177
03/12/18 01:03 PM
03/12/18 01:03 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
Do those fit inside stock wheel houses?
Re: Which street drag tires? [Re: ScottSmith_Harms] #2465207
03/12/18 02:23 PM
03/12/18 02:23 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Yes. It had been a while since i had that car( 70 b3 duster with W5 motor, many members here know the car)
If you want to see what the tires look like on it..... go to youtube.....” don’s wheelstand”
You can see how the tires fit. They were Just barely inside the wheel lips. Again 10 inch wheel in the video, so tire lays out more than wgen i had 8 inch wheels on it several years earlier
With more backspace tire would rub to inside on s/s springs. Its important tire is centered in wheelwell
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Which street drag tires? [Re: 4mopower] #2465257
03/12/18 03:40 PM
03/12/18 03:40 PM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
See my post above...Highly reccomended.
Re: Which street drag tires? [Re: ScottSmith_Harms] #2465407
03/12/18 09:04 PM
03/12/18 09:04 PM
Maryland
twayne24365 Offline
twayne24365  Offline
Maryland
My car might make 450 crank hp, it’s a 72 swinger with a 383, 4 speed with McLeod clutch, 4.56 gears and a spool, ss springs and 90/10 Calvert shocks up front. 255/60/15 mickey Thompson drag radials and I promise if your trying to hook on the street the MT drag radials aren’t the way to go, they are an awesome tire but a stick car on the street isn’t going to hook very well with them.
From a stop if I dump the clutch it’s useless, from a 10mph 1st gear roll it spins 1st 2nd and into 3rd, from a 2nd gear roll it’s ok. After my radials burn off I’m going to try a bias slick. If someone can hook a stick car to the street through the drag radials please fill me in lol
Page 3 of 3 1 2 3
