69 Dart Rear wheel fitment #2463197
03/08/18 05:45 PM
03/08/18 05:45 PM
Moparts
SSDart Offline OP
SSDart  Offline OP
Moparts
I'm trying to figure out what rim best fits the rear of my Dart?
Leaf springs moved up against the frame rail(not under) Stock Axle width.
I remember years ago being able to fit a 28.5 X 9 Firestone under the car with a 7 inch Auto Drag. ( I can't remember the backspace. )
I'm thinking a 15 X 7 3 1/2 back space would work...
Anyone care to share there experience with this?? TIA
Re: 69 Dart Rear wheel fitment [Re: SSDart] #2463253
03/08/18 06:55 PM
03/08/18 06:55 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I would guess it would want closer to a 4 1/2" to 5" backspace with either a 7-8" wide wheel...
Re: 69 Dart Rear wheel fitment [Re: SSDart] #2463309
03/08/18 08:34 PM
03/08/18 08:34 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
15 x 8 with 4.5 back spacing 29"x 10.5 tire
Re: 69 Dart Rear wheel fitment [Re: SSDart] #2463430
03/08/18 11:36 PM
03/08/18 11:36 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
With my springs moved in 3/4" and the rear end moved back 1/2" I ran a 15 X 8 with a 5.5" bs and a 275 radial.
Re: 69 Dart Rear wheel fitment [Re: SSDart] #2463440
03/08/18 11:49 PM
03/08/18 11:49 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Years ago I put some 8x26 slicks on lil red/warlock 15x8's and fit was decent after trimming a wee bit of the lip up above.
Re: 69 Dart Rear wheel fitment [Re: buildanother] #2463845
03/09/18 04:52 PM
03/09/18 04:52 PM
Moparts
SSDart Offline OP
SSDart  Offline OP
Moparts
I ordered Billet Specialties 15X 8 5 1/2 B.S. today.
Next is my front dilemma Time to get rid of the 4 inch bolt pattern
Re: 69 Dart Rear wheel fitment [Re: SSDart] #2464118
03/10/18 01:29 AM
03/10/18 01:29 AM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I think you will be happy with that choice.
You can ordered a Wilwood or Strange front disc conversion for whatever spindle you currently have. May be easier than trying to find a good factory setup...
Re: 69 Dart Rear wheel fitment [Re: SSDart] #2464155
03/10/18 03:06 AM
03/10/18 03:06 AM
Cab_Burge Online work
Cab_Burge  Online Work
If your wanting to go cheap the 1973 to 1976 stock OEM A body disc brakes (4.5 inch bolt pattern with bigger wheel bearings) with the upper A arms and lower control arms bolt right on up scope
Re: 69 Dart Rear wheel fitment [Re: Cab_Burge] #2464334
03/10/18 04:26 PM
03/10/18 04:26 PM
Easton, PA
68DART360 Offline
68DART360  Offline
Easton, PA
Cab_Burge has the right idea. That's the way to go for cheap. I found a complete setup off a valiant in a junkyard and it had new brake rotors and pads!
Re: 69 Dart Rear wheel fitment [Re: Sammy] #2464466
03/10/18 09:24 PM
03/10/18 09:24 PM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
This is my combo.
Re: 69 Dart Rear wheel fitment [Re: Forest] #2464679
03/11/18 12:38 PM
03/11/18 12:38 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I used the Strange kit. Went from '72-'73 A-body factory disc setup and lost over 50 lbs too. !!!
If you like drag racing, support your local track.
Re: 69 Dart Rear wheel fitment [Re: Cab_Burge] #2469911
03/21/18 07:29 PM
03/21/18 07:29 PM
Moparts
SSDart Offline OP
SSDart  Offline OP
Moparts
Thanks Cab I'm doing the 65 Mustang Disk conversion for now...
