Re: Big block headers for duster
[Re: Derrick Payne]
#2462078
03/06/18 05:12 PM
03/06/18 05:12 PM
Posts: 1,430 Martinsville, IN
cdwmotorsports
Martinsville, IN
I love my Hooker fenderwells. They aren’t in the way when doing maintenance. I have 205/65/15 front tires. Have never tried to put anything else on there so I can’t say if they’ll fit with your tires.
eBay-cdwmotorsports
[Re: Derrick Payne]
#2462208
03/06/18 09:02 PM
03/06/18 09:02 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I used Proparts semi-fenderwell on my 9 second Dart. IIRC 2 tubes go through the fenderwell on the drivers side and one tube on the passenger side.
[Re: 493_DART]
#2462215
03/06/18 09:04 PM
03/06/18 09:04 PM
ProSport
Akron, Ohio
I have the Hedman fenderwell race headers. Love them. Everything is easy to work on and i can have both headers out of the car in under 10 minutes What size front tire are you running? Are you running an exhaust system? Any pics?
[Re: 493_DART]
#2462317
03/06/18 11:20 PM
03/06/18 11:20 PM
dartman366
Mt. Vernon, Ohio
I have the Hedman fenderwell race headers. Love them. Everything is easy to work on and i can have both headers out of the car in under 10 minutes The only issue I have is the tight fit with the no logo Indy cast valve covers, had to notch the outer edge for two tubes on the passenger side.
[Re: Derrick Payne]
#2462355
03/07/18 12:07 AM
03/07/18 12:07 AM
Posts: 7 Mt.Vernon,KY
Derrick Payne
Mt.Vernon,KY
Has anybody used the ones Bob Mazzolini sells I hear there the same as the pro parts is this true
[Re: Dave Hall]
#2462417
03/07/18 03:06 AM
03/07/18 03:06 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
A naked shot Those are Hedman headers? They look like an excellent product! They almost look stainless? Did you hot, clear paint them somehow? Yes Dave, Headman Headers straight out of the box uncoated , they have black ceramic coating now.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: Derrick Payne]
#2462433
03/07/18 05:23 AM
03/07/18 05:23 AM
Posts: 43,095 Bend,OR USA
Cab_Burge
Has anybody used the ones Bob Mazzolini sells I hear there the same as the pro parts is this true No, his have bigger primary tubes, Pro Parts where two inch, Maz are 2 1/8 I bought a set of the original Pro Parts from Bill Bgashaw before he sold out and close the doors on Pro Parts for my 1969 GTS Dart 383 4 speed car, they don't fit worth a hoot on low decks with stock heads I called him about this and was told their for 440 motors in A bodies with stock heads, not low deck B motors
[Re: RapidusMaximus]
#2462465
03/07/18 10:58 AM
03/07/18 10:58 AM
Posts: 20,144 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Funny this came up right now...I'm in the designing stage of building a 67 Dart and I'm hung as whether to go stroker small block or big block...one of the deciding factors is headers... How fast you want to go would be my biggest concern. If you are happy in the 10's and slower a small block stroker in a 67 Dart is the smart choice. Lean on it a little harder and you are in the 9's.
[Re: ProSport]
#2462698
03/07/18 05:59 PM
03/07/18 05:59 PM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
I have the Hedman fenderwell race headers. Love them. Everything is easy to work on and i can have both headers out of the car in under 10 minutes What size front tire are you running? Are you running an exhaust system? Any pics? 165R 15 skinnies--they rub when i turn hard--doesnt bother me. No exhaust .
