Re: What lifters for 73 440 street car? change in car?
[Re: RayR]
#2462310
03/06/18 11:10 PM
03/06/18 11:10 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
Ray, does the cam/lifters have 300,000 miles? You don't want to hear it, but if it does I HIGHLY recommend you put in a new cam/lifters/timing chain....seriously. (Option A)
Option B --> no cash, then just replace that ONE lifter & buy a stock auto parts one. IF you get lucky & the lifter isn't worn on the bottom (pretty likely it is worn & "mushroomed out"), then the big/strong magnet on a stick would work just pulling the valve covers & removing the rocker arms. After 300,000 miles, your odds aren't good that this will work, but what the heck?
Option C --> if the magnet doesn't work, then pull off the intake/carb as one piece. You might have to pry up on the lifter from beneath. If it's really stuck, you can pull out the camshaft & push it down & into the cam area and catch it (them) with a cardboard tube that fits inside the cam hole with a slot cut in it as a "catch tray". Someone on this board told me this trick recently and I just used it myself about 3 weeks ago...worked like a charm.
Personally, I'd put another cam/lifter/timing chain in it and try to go at least another 100,000 if it the engine doesn't smoke. You can get a better look at the valve gear with the intake & valve covers off.
If the motor was running really well, you might take a look at the valve stem seals while you're in there. Lastly, on a street car, there's no need at all for "fancy" lifters
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: lewtot184]
#2463695
03/09/18 01:24 PM
03/09/18 01:24 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
at 300,000 miles change cam and lifters together. I gotta agree here. I just replaced timing chain, cam, lifters, rockers, and push rods. I admit it was because I took it apart a long time ago, and didn't know they had to go back together where they were. Cam is a Hughes piece and the rest is stock replacement, from Rock-Auto. Much cheaper than a failed com lobe would have been.
I have mechanical Aptitude. I can screw up anything.
[Re: RayR]
#2463835
03/09/18 04:34 PM
03/09/18 04:34 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
There is a small, inexpensive lifter removal tool that catches the snap ring lip of the lifters very well. I have that tool and a bit heavier tool that actually has a small slide hammer that helps pull out lifters past the engine varnish.
The lighter tool allows you to pull the lifters out without removing the intake. You may be able to get away with de-varnishing the internals of the lifters, but make sure its not an exhaust leak too.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: RayR]
#2464228
03/10/18 11:58 AM
03/10/18 11:58 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
If lifter gets stuck to be removed with the telescopic magnet due the "burnt oil ridges" on bottom, a hard wire bent like a hook to catch the inner snap ring will do the job too to leave the bore, then the magnet if falls from the wire after leave the bore.
