Re: Reminder: Don't put your carb away "wet"...
[Re: tboomer]
#2461756
03/05/18 11:42 PM
03/05/18 11:42 PM
dartman366
Mt. Vernon, Ohio
Mine fired right up yesterday....Still has a little Sunoco supreme in it. what Ted said.
[Re: BradH]
#2461963
03/06/18 12:44 PM
03/06/18 12:44 PM
Posts: 5,162 CT
GTX MATT
CT
I only run Sunoco 110 even in my lawn equipment and I add 1 bottle of Stabil per gallon when I store it for more than a week. I also put brand new plugs in, change the oil (only stuff that costs > $15 per quart) and only prep it for storage only on odd days of the month.
[Re: BradH]
#2461991
03/06/18 01:45 PM
03/06/18 01:45 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Brad, if you use a small pic and get it down into the slots where the fuel runs around the needle, and very gently pry/wiggle it, it will pop free.
[Re: tboomer]
#2462028
03/06/18 03:24 PM
03/06/18 03:24 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Mine fired right up yesterday....Still has a little Sunoco supreme in it. Yep, every time.............
[Re: BradH]
#2462039
03/06/18 03:51 PM
03/06/18 03:51 PM
fast68plymouth
So. Burlington, Vt.
If you grind a new point on the pick, nice and sharp, you might be able to have it "dig in" to the top of the needle while you try and wiggle it around. I find the needles getting stuck against the seats isn't that uncommon at all. It usually just takes the tiniest amount of movement to break them free.
[Re: SomeCarGuy]
#2462332
03/06/18 11:33 PM
03/06/18 11:33 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
So nobody runs something like Stabil 360 for ethanol? Does that not work for this junky fuel? Not tried 360, but a friend turned me on to using the stabil marine which supposed deals better with ethanol problems. No issues since I started using it years ago. Both my challenger and my GSXR have sat for months on end with no noticeable ill effects. Just recently rebuild the holley on the challenger and there was zero crud. I will back up and say I had an issue with the motorcycle from dumping a bottle of seafoam or something in the tank after storage. Barely ran to the point of not being safe to drive (stalling, no power) pulled the plugs and they were fouled some weird red color. Changed plugs and it ran like a champ again. Note to self - don't mix and match fuel additives in the same tankful.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: BradH]
#2462573
03/07/18 02:26 PM
03/07/18 02:26 PM
BradH
Found the secondary accel pump needle below the nozzle screw on one of the aluminum body carbs we dynoed in October has corroded in place.
1. Soaked it from both sides w/ PB Blaster 2. Got out my skinny little pick collection and tried my best to dislodge it 3. Air pressure from my compressor thru a rubber-tipped nozzle 4. Even tried to force a pick into the top of the check needle w/ no luck Final option... and the one I did not want to resort to... drill it out. But that's what I ended up doing cuz nothing else worked. Then I had to take a series of drill bit shanks and resize the bottom of the hole to make sure the needle would drop all the way to the bottom and not get stuck again. The odd thing is the remains of the check needle don't look corroded, yet this thing was completely stuck in the passage.
[Re: BradH]
#2462699
03/07/18 06:00 PM
03/07/18 06:00 PM
Posts: 4,457 Washington
madscientist
Washington
Wow that's crazy. I've had them stick before but not like that! I usually pull the bowl off and with a rubber tipped nozzle blow backwards up the passage and the pop right out.
The problem is just what you'd think it would be. If you don't hold you hand over the nozzle hole the check valve will end up bouncing off everything in the shop and you need to get your spare out!
[Re: Thumperdart]
#2463288
03/08/18 07:48 PM
03/08/18 07:48 PM
BradH
Get the steel check valves from BLP and you should be golden........ I only see one part # for check valves on BLP's web site. I definitely want steel, instead of brass or aluminum like my carbs all seem to have now. It's not hard to find articles online about the corrosive effect of ethanol on brass & aluminum, but steel seems to resist it much better.
