Tools that have helped greatly
#2461266
03/05/18 12:49 AM
03/05/18 12:49 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I thought it would be great to start a thread.. where we could share.. info on tools that have made life easier.. I think whether they're store boughten.. or custom made.. I'm always in the quest for looking for an easier or better way..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Tools that have helped greatly
[Re: Pacnorthcuda]
#2461275
03/05/18 01:21 AM
03/05/18 01:21 AM
Posts: 20,145 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Flowbench. I bought two and then I built one and it set up exactly how I wanted it. It has taught me so much over the years
[Re: WHITEDART]
#2461356
03/05/18 09:09 AM
03/05/18 09:09 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Eastwood tubing flare tool. Very rarely am I impressed by a tool. This thing never gives a bad flare. Use it with steel, nicad, and stainless. Perfect every time.
[Re: WHITEDART]
#2461379
03/05/18 10:21 AM
03/05/18 10:21 AM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
Does it have a feature that bonks you on the head and reminds you to put the flare nut on?
68 Barracuda Formula S 340
[Re: WHITEDART]
#2461401
03/05/18 11:44 AM
03/05/18 11:44 AM
Posts: 11,994 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I had thought that the battery impact was the handiest thing I had found in a long time. Until I found the battery ratchet.
It's even handier because I use it much more often than the impact. Plus it has a little light which I felt, at first, was gimmicky. But, it really helps these old eyes.
Master, again and still
[Re: FurryStump]
#2461438
03/05/18 01:00 PM
03/05/18 01:00 PM
WHITEDART
bean town ....Ca
This is one of those tools that I've always just had hanging around.. weather I'm doing valve spring keepers or reaching for a washer or not that I've dropped.. it seems as though this is one of the tools that I find myself using more and more.. typically can be found at your local auto parts store or Grainger for around 10$
[Re: skrews]
#2461511
03/05/18 03:24 PM
03/05/18 03:24 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Wide band air fuel ratio gauge. This has been the most important tool for carb tuning and has made my life and others much easier..........
