Page 1 of 4 1 2 3 4
If you knew then what you know now... #2460110
03/02/18 08:30 PM
03/02/18 08:30 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
... would you have made different decisions as far as how you approached racing, or your choice of builds, or... ???
popcorn
Re: If you knew then what you know now... [Re: BradH] #2460118
03/02/18 08:38 PM
03/02/18 08:38 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
The only thing I would have changed is I would have bought my heads up car while I was younger and my son still lived at home. At my age it’s hard doing a class like that by yourself. It may end up being another bracket car
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: If you knew then what you know now... [Re: BradH] #2460143
03/02/18 09:09 PM
03/02/18 09:09 PM
Washington
madscientist Offline
Washington
I would have never started.
Re: If you knew then what you know now... [Re: BradH] #2460151
03/02/18 09:11 PM
03/02/18 09:11 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I'd have been faster
Re: If you knew then what you know now... [Re: madscientist] #2460159
03/02/18 09:17 PM
03/02/18 09:17 PM
BradH Offline OP
BradH  Offline OP
I figured that comment would make it into the top 10 responses, but in by 2... wow! laugh2
Re: If you knew then what you know now... [Re: BradH] #2460161
03/02/18 09:19 PM
03/02/18 09:19 PM
gregsdart Offline
gregsdart  Offline
I would have done about everything differently! Skip the rb with 906 heads, save my nickels for B1 heads and a moly chassis.
Re: If you knew then what you know now... [Re: gregsdart] #2460169
03/02/18 09:25 PM
03/02/18 09:25 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
iagree gone big the first time!
Re: If you knew then what you know now... [Re: BradH] #2460170
03/02/18 09:28 PM
03/02/18 09:28 PM
popcorn
I would have never built and raced a 1970 Baracuda 4 speed with a Hemi in NHRA stock on a 9 inch wide slick tsk realcrazy
I should have weighed that car first as far as how much weight on the front tires and rear tires with me in it work
It had 2160 Lbs. on the front tires and 1280 lbs. on the rear without me in it back in 1976 before NHRA required the drivers weight in the drivers seat shock I never raced that car again after weighing it that day blush
That car had a minimum weight of 3440 Lbs. with out the driver after a run back then whiney
Re: If you knew then what you know now... [Re: BradH] #2460172
03/02/18 09:32 PM
03/02/18 09:32 PM
Creston, Iowa
3
340man4ever Offline
340man4ever  Offline
Creston, Iowa
Dana 60 instead of 8 3/4, Super Sprag, LBA valve body and aftermarket front drum in 727....DAMHIK................
Curator at Adams County Speed Shop
Re: If you knew then what you know now... [Re: BradH] #2460185
03/02/18 10:05 PM
03/02/18 10:05 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I would have started racing at a younger age, and learned how to do more on my own sooner like welding, building transmissions and rear ends. Lastly I wish I found this forum sooner!
Re: If you knew then what you know now... [Re: BradH] #2460198
03/02/18 10:20 PM
03/02/18 10:20 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
When we ran the lickety split car in the 90's and 2000's, I wouldn't have kept exclusivly turning the rear shock compression knob all over the place and wondering why it didn't help the traction. Lol
Re: If you knew then what you know now... [Re: BradH] #2460216
03/02/18 10:46 PM
03/02/18 10:46 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I would of taken photos of things I built, I wouldn't have taken 8 years off.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: If you knew then what you know now... [Re: BradH] #2460232
03/02/18 11:26 PM
03/02/18 11:26 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
When I was 10 years old I was going to the track with my Dad racing his 63 Max Wedge car, about then he was 2 tenths off the Australian A/MP record before he threw the Brooks rods out the side of the block, that was 75/76, 20 years later we got the car back and I found 5.14 gears in the diff !!!
What RPM is that ? 120mph 32" tire.
Im no guru but Im sure I could have got that record.
1963 Plymouth Max Wedge
1971 Barracuda
Re: If you knew then what you know now... [Re: BradH] #2460233
03/02/18 11:28 PM
03/02/18 11:28 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I would have chosen a far more lucrative and secure line of work. And bought a lot more Hemis.
Re: If you knew then what you know now... [Re: BradH] #2460235
03/02/18 11:39 PM
03/02/18 11:39 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
I would have done more research and chatted with more people before starting a build. Would of went to an aftermarket block out of the gate.
Doing those simple things and I’d have enough $ left over to do a second car. That I know for sure.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: If you knew then what you know now... [Re: BradH] #2460240
03/02/18 11:46 PM
03/02/18 11:46 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I would have bought up a bunch of 68-72 muscle cars in the late 70's when people were getting rid of them. Held onto them till the 2000's
Re: If you knew then what you know now... [Re: BradH] #2460244
03/02/18 11:53 PM
03/02/18 11:53 PM
wine country
8
8urvette Offline
8urvette  Offline
wine country
I would have built a LS based twin turbo fuel injected E85 engine instead of my 540 victor headed gasengine.... stirthepot
It would still be in my barracuda tho whistling
Re: If you knew then what you know now... [Re: nss guy] #2460245
03/02/18 11:54 PM
03/02/18 11:54 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I wouldn't of followed any of Brad h.s, engine and car building threads waiting for results that never have happened. Besides that I would of Bought all the Hemis I could of back in the day. Other then that, would of done it the same, it was a journey. up
Re: If you knew then what you know now... [Re: BradH] #2460250
03/03/18 12:06 AM
03/03/18 12:06 AM
UK
rb446 Offline
rb446  Offline
UK
Building my 440SP motor with stock pistons and that 290@.050 solid wasn't the ticket, running the 14x32's @4.5psi was no good just because everyone else ran them at that back then, and the 90/10's weren't the best, probably would've done better with some used stock shocks, too much front end rise, apart from that the car still ran well and managed 10.7's with 2.14 906's but I'm sure I could've gone quite a bit quicker today with the same set up just changing those things, at the end of the day my goal was a 9 sec pass which I managed with a small shot of spray so not a bad way to bow out of the sport in 1990.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: If you knew then what you know now... [Re: rb446] #2460252
03/03/18 12:20 AM
03/03/18 12:20 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
I would have spent more money on getting good suspensions and rearends under my cars.
Experimenting with 8 3/4 rears and Superstock springs was an exercise in wallet lightening and not much else.
'63 Dodge 330
11.19 @ 121 mph
Page 1 of 4 1 2 3 4
