Re: Looking for a TRUE Bronze Pilot bushing [Re: Stanton] #2459783
03/02/18 04:42 AM
03/02/18 04:42 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Originally Posted By Stanton
So I haven't seen anyone suggest the obvious here ... Brewers or Passon !!!
http://www.brewersperformance.com/proddetail.php?prod=PB329
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Looking for a TRUE Bronze Pilot bushing [Re: wally426ci] #2459819
03/02/18 10:08 AM
03/02/18 10:08 AM
Maryland
wally426ci Offline OP
Maryland
Thanks ya'll
I found a sintered bronze piece from the shop that had my tranny. I did have an order in for PBH286HD from Fisher Auto Parts so I'll follow up if that is a parts store option.
As for rollers - I'd prefer not to have something else that could fail in a big way.
That's just, Like, my opinion man.
-Jeff Bridges
Re: Looking for a TRUE Bronze Pilot bushing [Re: wally426ci] #2459837
03/02/18 11:06 AM
03/02/18 11:06 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Tell me MORE about these Roller Failures? Especially the catastrophic ones.
For 15 years I have used them in all my cars. Most of those cars get the snot whipped out of them. Transmissions are always on the floor for maintenance...NEVER a problem with the rollers. Input shafts always look perfect, no scuffing, no galling no discoloration.
Actually I did recently have a issue where I swapped in a different shortblock into my Duster. I ran it for a while and then would miss a shift every now and then. As it turned out the crank had a bit of wear and the roller popped out. So the input was unsupported. No catastrophic failure... Just a missed shift. On the engine I ended up putting a bushing in it.
I'm thinking if the roller is being blamed for catastrophic failure the car has other problems
Re: Looking for a TRUE Bronze Pilot bushing [Re: moparpoolman] #2459872
03/02/18 12:45 PM
03/02/18 12:45 PM
NE
moparpoolman Offline
NE
Originally Posted By moparpoolman
just bought one last week, looks just like the picture
NATIONAL PB286HD
http://www.rockauto.com/en/moreinfo.php?pk=221635&cc=1078859&jsn=436
Magnet does not stick to it. Seems to me what the OP is looking for. beer
Re: Looking for a TRUE Bronze Pilot bushing [Re: moparpoolman] #2459947
03/02/18 03:49 PM
03/02/18 03:49 PM
Maryland
Maryland
NATIONAL PB286HD
Picking it up today just to have it on the shelf in case. Thank you!
Re: Looking for a TRUE Bronze Pilot bushing [Re: scatpacktom] #2460686
03/04/18 12:53 AM
03/04/18 12:53 AM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
My 01 2500 5.9 Magnum Ram had the roller come apart- preventing clutch disengagement as the rollers got swedged between the bearing case and input shaft. Was lucky that it was late at night and only 20 miles from home: was able to time the lights and such in order to get home. Galled the input shaft a little bit in the process.
Am not a roller set up basher (am running it in two old Mopars): am just passing along a failure instance.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
