SB 318/360 Magnum in 68 B-body #2459690
03/02/18 12:19 AM
03/02/18 12:19 AM
oberlin, Ohio
Rapid340 Offline OP
Rapid340  Offline OP
oberlin, Ohio
Can anyone point me to a decent/easy motor mount bracket solution for someone installing SB 318/360 magnum engine in place of an LA 318 in a stock 68 B-body? The magnum engine my friend is installing has the old 340/360 style mounting ears of course.
thanks
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: SB 318/360 Magnum in 68 B-body [Re: Rapid340] #2459695
03/02/18 12:29 AM
03/02/18 12:29 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
On the drivers side, you need the 340 bracket . . . ask me how I know - 360 in my 70 sport satellite. The 340 bracket moves to the other side of the mounting ear on the 360. My car was originally a 318.
Re: SB 318/360 Magnum in 68 B-body [Re: a12rag] #2459721
03/02/18 01:00 AM
03/02/18 01:00 AM
oberlin, Ohio
Rapid340 Offline OP
Rapid340  Offline OP
oberlin, Ohio
70 71 E-body 340 bracket?
Any good sources for one?
Re: SB 318/360 Magnum in 68 B-body [Re: Rapid340] #2459867
03/02/18 12:25 PM
03/02/18 12:25 PM
a12rag Offline
a12rag  Offline
I got mine from a buddy . . . ummm, guess you will have to look around . . .
Re: SB 318/360 Magnum in 68 B-body [Re: Rapid340] #2459948
03/02/18 03:50 PM
03/02/18 03:50 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Could probably modify the 318 bracket. Thought it was just one hole that wasn't there.
Angry white pureblood male
Re: SB 318/360 Magnum in 68 B-body [Re: Rapid340] #2459988
03/02/18 04:56 PM
03/02/18 04:56 PM
a12rag Offline
a12rag  Offline
Nope . . . the 340 is different . . . (drivers side) . . .
Re: SB 318/360 Magnum in 68 B-body [Re: Rapid340] #2460166
03/02/18 09:22 PM
03/02/18 09:22 PM
Andrewh Offline
Andrewh  Offline
I thought the 318 one is just narrower, so people used spacers.
I bought new ones from here.
http://www.engine-swaps.com/Pages/ProductsYear/66.72bBody.html
Re: SB 318/360 Magnum in 68 B-body [Re: Andrewh] #2460875
03/04/18 01:57 PM
03/04/18 01:57 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
340-360 B/E body engine mounting brackets, same as 1971-1972-1973 C-body 360
you can use 318 brackets in a pinch. the passenger side is always the same on those bodies/engine series/the drivers side for a 340-360 is narrower to match the ears on the engine block. its only the top bolt on one side that is narrower, bolt up the 318 drivers side mount to the 340-360 block using the holes that line up....you will see a small gap between block ear and mount hole which can be made up with washers or a cut down alternator spacer. the rubber insulators are the same for all b/c/e v8s
Re: SB 318/360 Magnum in 68 B-body [Re: Joesixpack] #2460878
03/04/18 02:00 PM
03/04/18 02:00 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
273-318 b/c/e engine mounting brackets
both have the same width ,ie spacing between mounting sides
Re: SB 318/360 Magnum in 68 B-body [Re: Joesixpack] #2460879
03/04/18 02:01 PM
03/04/18 02:01 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
340-360 b/c/e mounting brackets, narrow at the top of the drivers side
Re: SB 318/360 Magnum in 68 B-body [Re: Joesixpack] #2460880
03/04/18 02:02 PM
03/04/18 02:02 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
340-360 b/c/e
Re: SB 318/360 Magnum in 68 B-body [Re: Joesixpack] #2460881
03/04/18 02:03 PM
03/04/18 02:03 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
340-360 b/c/e
Re: SB 318/360 Magnum in 68 B-body [Re: Joesixpack] #2460888
03/04/18 02:10 PM
03/04/18 02:10 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
1967-1972 340-360 A-body which are totally different and wont work on b/c/e
i used to buy&sell these mounts for over 30 years so i do have some knowledge regarding fitment.
Re: SB 318/360 Magnum in 68 B-body [Re: Joesixpack] #2460894
03/04/18 02:17 PM
03/04/18 02:17 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
273-318 b/c/e drivers side width(thanks to my buddy GREG PURCELL)
Re: SB 318/360 Magnum in 68 B-body [Re: Joesixpack] #2460895
03/04/18 02:18 PM
03/04/18 02:18 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
340-360 b/c/e drivers side width(thanks to Greg Purcell for photo)
Re: SB 318/360 Magnum in 68 B-body [Re: Joesixpack] #2460899
03/04/18 02:24 PM
03/04/18 02:24 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
early 273 318 b&c body passenger side bracket with only 3 mounting holes, you have to drill the 4th hole in the middle of the bracket straight across from the hole on the other side to bolt correctly to a 340-360
Re: SB 318/360 Magnum in 68 B-body [Re: Joesixpack] #2460902
03/04/18 02:27 PM
03/04/18 02:27 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
b/c/e 318-340-360 passenger side with the 4th mounting hole
Re: SB 318/360 Magnum in 68 B-body [Re: Joesixpack] #2460904
03/04/18 02:29 PM
03/04/18 02:29 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
318 poly 63-65 bbody mounts which you can use to bolt in a 392 Hemi in any 63-64-65 bbody! same bolt pattern on engine block as a 318 poly!
