Brakes, or lack there of.
#2455856
02/22/18 09:38 PM
02/22/18 09:38 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
OK, I just bought a 69 Chrysler 300 last week and the brakes are terrible. I changed out the worn front shoes, but that didn't help. The pedal may move a total of a half inch, and it is rock hard. I,m thinking the booster is bad. What do you guys think? The only other booster I have had to replace leaked air, but I can't hear anything from this one. The car has been sitting for quite a while.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Brakes, or lack there of.
[Re: rattler]
#2455863
02/22/18 09:49 PM
02/22/18 09:49 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Booster could be rusted. Master cylinder could be rusted. What does the fluid look like?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: ahy]
#2455903
02/22/18 11:18 PM
02/22/18 11:18 PM
Posts: 1,607 Western Washington
Sixgun
Western Washington
IIRC...with the engine off, pump the brakes a few times to use up whatever reserve vacuum there is. Holding the pedal down FIRMLY, start the engine. If the pedal sinks appreciably, the booster is bad.Again this is if I recall the NAPA days correctly. Hope this helps.
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
[Re: rattler]
#2455906
02/22/18 11:25 PM
02/22/18 11:25 PM
rattler
Crofton, Ky.
The pedal is hard as a rock with or without the engine running. And it just barely is able to stop. I don,t think bleeding the brakes is the issue, if it was they would be spongy. The fluid color is typical brown like all old fluid.
[Re: rattler]
#2456024
02/23/18 09:20 AM
02/23/18 09:20 AM
rattler
Crofton, Ky.
I'll check on the booster by unbolting it and checking rod movement. Definitely have vacume, and the wheel cylinders all look fine.
[Re: rattler]
#2456364
02/23/18 09:45 PM
02/23/18 09:45 PM
rattler
Crofton, Ky.
I pulled the master away from the booster today. Pedal easily travels to the floor. Started the car and it pulled the pedal back up with the vacume. I would find it hard to believe that all four wheel cylinders would have frozen up. So, I am still without brakes.
[Re: rattler]
#2456368
02/23/18 09:53 PM
02/23/18 09:53 PM
amxautox
Ahhh, but they can all rust up. If one is rusted from moisture, then the moisture is there in the fluid for all cylinders to rust.
Bleed some fluid from the other cylinders and see how rusty the fluid is.
Tom
author unknown
[Re: Dave Hall]
#2456623
02/24/18 12:11 PM
02/24/18 12:11 PM
Posts: 10,985 North Dakota
6PakBee
North Dakota
As someone who drove '69 C bodies when they were new, that power drum setup should be able to throw you into the windshield on a hard stop.
[Re: amxautox]
#2456654
02/24/18 01:04 PM
02/24/18 01:04 PM
RapidRobert
Master cylinder could be rusted. my bet
[Re: rattler]
#2457253
02/25/18 11:51 AM
02/25/18 11:51 AM
rattler
Crofton, Ky.
Ok, I pulled a couple of wheels yesterday and had my wife depress the brake pedal slowly. Much to my surprise, the wheel cylinders are frozen up. I have never seen a wheel cylinder stuck like that. Always worked or leaked. Learned something new. To my disbelief, none of the three major parts stores in town even list wheel cylinders. Might have to buy them from Summit.
[Re: rattler]
#2457263
02/25/18 12:04 PM
02/25/18 12:04 PM
amxautox
If the bleeders aren't frozen rusted then bleed the brakes while waiting for the new cylinders, and before installing the new wheel cylinders. Get ALL the old fluid out as there is probably lots of moisture in the fluid and it could rust up the new cylinders. And double check the master cylinder.
Tom
author unknown
[Re: amxautox]
#2457278
02/25/18 12:27 PM
02/25/18 12:27 PM
Posts: 20,506 north of coder
moparx
i have run into frozen wheel cylinders so many times i lost count. and to make matters even more interesting, this also happens on daily drivers as well. when the fluid gets moisture in it [the fliud is "hydroscopic", which means it absorbs water] and turns that nasty brown/black color, problems can, and do, occur. this applies to DOT 3, 4, and 5.1 fluids only. DOT 5 doesn't absorb water because of it's synthetic nature, but i have also experienced frozen cylinders [although rare] using that because the cylinders had collected water at the bottom of the cylinders, leading to rust in that area only, just enough to make it stick. after taking the cylinder apart, the area could "usually" be polished out without making the bore out of round, then using a kit, put back in service.
