Re: Neutral safety switch connection in racecar?
[Re: 70satelliteguy]
#2456245
02/23/18 05:21 PM
02/23/18 05:21 PM
Posts: 12,318 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
What kind of shifter? Often times it's easier to use a shifter mounted switch. If the car is using the stock harness and starter relay, then a new 3 wire plug will fix you up. NAPA ECH EC187 Advance PT5667
[Re: J_BODY]
#2457280
02/25/18 01:33 PM
02/25/18 01:33 PM
Posts: 1,303 Penna
70satelliteguy
Penna
"I went with this newer style N safe switch on my old car and got the pigtail at work for it. That old style connector was a joke. "
J body. Will this fit 727? Have a part Number? Pig tail that fits this? Thanks Mike
#2457357
02/25/18 04:13 PM
02/25/18 04:13 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Looks like an Autozone pt.# is CR446 for the switch and 1070 for the connector kit. Mid 2000s RWD truck
[Re: CMcAllister]
#2457377
02/25/18 05:04 PM
02/25/18 05:04 PM
Posts: 4,806 Wichita
GY3
Wichita
I use a blue butt connector on the center pin and crimp it down to where it snaps off and on. Seems to work so far.
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
#2457443
02/25/18 07:16 PM
02/25/18 07:16 PM
Posts: 26,538 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If the '67 727 has the original style valve body and rooster comb (middle in the pic below), it's not really compatible with the 3-prong switch.
Pre-'69 uses the single threaded stud switch.
#2457969
02/26/18 05:48 PM
02/26/18 05:48 PM
John_Kunkel
Rio Linda, CA
Don't know what style rooster comb but now it has a transbrake valvebody.
Remove the switch and look in the hole; compare what you see to my pic.
#2458120
02/26/18 10:31 PM
02/26/18 10:31 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
On a race car I would use the neutral safety switch that is probably built into your aftermarket shifter to ground out the wire that now runs to factory switch. Then put a o-ring plug in the factory switch location.
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#2458303
02/27/18 12:16 PM
02/27/18 12:16 PM
Posts: 1,303 Penna
70satelliteguy
Penna
Removed the switch and it is a blue A&A transbrake valvebody showing. .Can't tell what the rooster tail looks like. I think I am just going to Gorilla glue a connection to the center prong and be done with it. Mike
#2458473
02/27/18 05:09 PM
02/27/18 05:09 PM
John_Kunkel
Rio Linda, CA
Removed the switch and it is a blue A&A transbrake valvebody showing. .Can't tell what the rooster tail looks like. What you're seeing is the plastic shoe on the rooster comb, they come in several colors. The single threaded stud switch (center in my pic) will work with the plastic shoe.
