CRT now has a nice full manual valve body, including overdrive with a brake. No solenoid for the OD shift. They come in LU and non LU. They are reverse pattern though. Easy as a shifter change or CRT also has some shifter gates for stock shifters.
You never said what this is in or why it needs to be a forward pattern.
