Re: Getting mixed feelings on Penn Grade Oil
[Re: Hot 340]
#2459575
03/01/18 08:30 PM
03/01/18 08:30 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Well, everyone is saying it has changed. Nobody is saying exactly what. But I read it on the internet so it must be true. 3 reputable engine builders said they stopped using it for a reason. I tend to believe 3 engine builders that sump most if not all the engines they build for customers.
[Re: 1964superstock]
#2459698
03/02/18 12:35 AM
03/02/18 12:35 AM
Posts: 3,392 cheshire, ct
davesmopars
cheshire, ct
We stopped using BP years ago. A lot of the Engines that come in for freshen ups that run BP have worn rocker shafts and Piston Pins. We only use Driven Brand Oil, every Big Block we Dyno has BR50 in it. In a lot of our high HP Drag engine we use XP3 after dyno but in most cases the HR series oil is a good choice. We use the 15/50 in our bracket style engines. Thanks for this info. What oil grade do you recommend for a street strip 505 440 stroker big block, using a solid flat tappet cam, 259/263 @ 050. My 505 engine dyno'd at 620 HP, fun street car. Would you still recommend 15w-50 Driven Engine Oil like bracket type engines, or use 10w-30 or 10w-40 instead? My 505 stroker had really high oil pressure last time I used Brad Penn 20w-50 oil, so I switched to straight 30W Brad Penn. Reading all this makes me a little leary of using BP oil any longer. Your recommendation is appreciated. Thanks. I also was using 20/50 Brad Penn running similar motor 604 Hemi solid roller so also would like to hear recommendation. street / strip mostly street
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: davesmopars]
#2459849
03/02/18 11:29 AM
03/02/18 11:29 AM
Posts: 12,039 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
We stopped using BP years ago. A lot of the Engines that come in for freshen ups that run BP have worn rocker shafts and Piston Pins. We only use Driven Brand Oil, every Big Block we Dyno has BR50 in it. In a lot of our high HP Drag engine we use XP3 after dyno but in most cases the HR series oil is a good choice. We use the 15/50 in our bracket style engines. Thanks for this info. What oil grade do you recommend for a street strip 505 440 stroker big block, using a solid flat tappet cam, 259/263 @ 050. My 505 engine dyno'd at 620 HP, fun street car. Would you still recommend 15w-50 Driven Engine Oil like bracket type engines, or use 10w-30 or 10w-40 instead? My 505 stroker had really high oil pressure last time I used Brad Penn 20w-50 oil, so I switched to straight 30W Brad Penn. Reading all this makes me a little leary of using BP oil any longer. Your recommendation is appreciated. Thanks. I also was using 20/50 Brad Penn running similar motor 604 Hemi solid roller so also would like to hear recommendation. street / strip mostly street I am also "all ears".
Master, again and still
[Re: Chuck@Best_Machine]
#2459898
03/02/18 01:37 PM
03/02/18 01:37 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Its impossible for me to recommend one oil that would work for everybody. When we do our engines everything is in our control from bearings, bearing clearance, lifter choice, oil pump, pushrod oiling etc.
But I would suggest for a street / strip car it would be safe to start with the Driven HR 15W-50 Conventional oil, if you have excessive pressure ( 80 + ) with 190 deg oil temp then you might want to try a 10W-40 Chuck ...any experience with the Schaeffers?
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Sammy]
#2459963
03/02/18 04:16 PM
03/02/18 04:16 PM
Posts: 452 Monrovia, So-Cal, USA
racerhog
Wow... IF I could make one recommendation to all y'all that really need help.
USE WHAT YOUR ENGINE BUILDER TELLS YOU TO USE !!!! PERIOD !!!!! Most folks dont know jack about oils....
Bob(Cowboy)Hogan Monrovia So-Cal
[Re: racerhog]
#2460044
03/02/18 07:07 PM
03/02/18 07:07 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Some engine builders don't know jack about oils.... Not directed towards anybody on here, but just sayin...
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#2460133
03/02/18 08:55 PM
03/02/18 08:55 PM
BradH
Some engine builders don't know jack about oils.... Not directed towards anybody on here, but just sayin... Some engine builders don't know jack about building engines, either. But that would be another thread all its own.
[Re: BradH]
#2460137
03/02/18 09:02 PM
03/02/18 09:02 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
[Re: Tommy D]
#2463653
03/09/18 12:15 PM
03/09/18 12:15 PM
Sammy
Wind Gap,Pa.
Six pages in and not one account of a failure...just rumors. Is this "lube shaming" LOL
We've run Penn Grade (old Brad Penn) for years since losing three separate engines to cam failure. The failures sent debris through the engines and required total rebuilds in all cases. This with flat tappet cams. Since switching to Brad Penn, no failures.
Does anyone have a personal experience with a true, oil-related failure due to Penn Grade? I just bought another case of 10W30, and have no plans to change until proven it's not going to work. You must have missed this reply from Chuck@Best Machine who I trust, same with Todd@ Competition Wedge. Please read. We stopped using BP years ago. A lot of the Engines that come in for freshen ups that run BP have worn rocker shafts and Piston Pins. We only use Driven Brand Oil, every Big Block we Dyno has BR50 in it. In a lot of our high HP Drag engine we use XP3 after dyno but in most cases the HR series oil is a good choice. We use the 15/50 in our bracket style engines.
[Re: Mattax]
#2463678
03/09/18 12:57 PM
03/09/18 12:57 PM
Posts: 20,166 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I wonder if these same engines seeing wear have vacuum pumps sucking the oil away from piston pins and oil restriction issues to the rockers causing issues. Spray bar oiling??? I run the hell out of my crap and I'm not seeing it on my engines with Brad Penn 10-30. I'm not saying its not happening because those guys see a heck of a lot more engines than I see. Maybe i'm just lucky.
[Re: Sammy]
#2463693
03/09/18 01:23 PM
03/09/18 01:23 PM
BradH
So which DRIVEN Race Oil would be good for a race only engine shifting at 7600 small block? Going through the traps at 7770 rpm's My suggestion is to go to the Driven Racing Oil web site and download their product brochures and tech articles. If you read the details of each of their race oils, you'll often see guidance such as using a Xw30 for bearing clearances up to .0027"; Xw40 for up to .0030", etc. They have enough info across their available downloads that it should give you a pretty good sense of what will work for you.
