318 Running Rough and too rich
#245724
03/07/09 03:39 AM
03/07/09 03:39 AM
Posts: 90 Laurens, SC
Radio Joe
Laurens, SC
Car is a 1966 Fury with a 318 and an Automatic. Car runs and drives but it was running a bit rough and rich with the stock Stromberg carb. I had accellerator problems with the carb soI bougth a Holley 4412 (2300 series) and put it on. That definitely didnt help. Heres where I am and I could use some direction
Timing is set at 10btdc. It runs between 10btdc and 15 btdc but if I try to adjust further to 5 btdc the car dies.
New plugs, cap, ect ect. Cleaned the points (because the replacements didnt fit correctly)
Holley carb was rebuilt. AF screws do nothing. And to start the car I have to hold the pedal to the floor and crank for about 20 seconds before it runs.
The idle has to be kept a bit high to keep it running otherwise it is very choppy and stalls. Idle is definitely too high but I cant adjust it down or it dies. It si still kinda choppy even with the idle high.
It runs so rich it burns my eyes.
I could use some direction. Should I focus on the carb or the timing? seems to me if it was mostly the carb it would run smoother, just rich.
Re: 318 Running Rough and too rich
[Re: Radio Joe]
#245726
03/07/09 11:28 AM
03/07/09 11:28 AM
RapidRobert
yes. I'd pull the top off & check the float level 1st & I would get a set of new points & gap them @.016" EDIT I reread your post & the diff carb didn't help? though it's easily possible that the 2nd carbs' float is too high. I'm wondering if there's a vac leak though I dont know if that would make it run pig rich.
[Re: Radio Joe]
#245728
03/07/09 12:03 PM
03/07/09 12:03 PM
RapidRobert
Alright, Carb sounds Ok, I wonder if a plug wire(or 2) went open
[Re: Wedgeman]
#245731
03/07/09 03:45 PM
03/07/09 03:45 PM
Radio Joe
Laurens, SC
I found the problem..... While checking the compression all checkedgood (between 110 and 120) until I got to the #8 cylinder... That was at 190. When I released pressure in the tester gas came out. So I yanked the carb... Sure enough its beenleaking gas. Pulled it apart and it seems that the guy who rebuilt it ripped the power valve gasket and put it on anyway. There was a huge gap. I replaced the gasket, turned it over until all the gas was out of the cylinders and reinstalled the carb. Runs great now. I still need to do some tweaking but it runs very smooth and starts right up. Thats whaI get fo trusting someoneone without checking their work. Im SOOOOOO happy it runs so smooth now. ![](/ubbthreads/images/graemlins/punkrocka.gif) Sorry for the crappy picture but i took it with my phone.
[Re: Radio Joe]
#245733
03/08/09 08:29 AM
03/08/09 08:29 AM
Maybe your power valve is bad, a backfire on any older Holley's without the back flow preventer will definitely run bad when the PV is NFG.
[Re: Radio Joe]
#245736
03/08/09 03:01 PM
03/08/09 03:01 PM
Posts: 6,680 Va. Beach, Va
69superbee383
Va. Beach, Va
You said you pulled and cleaned the points. Make sure they are gapped properly or better yet set the dwell to factory settings and then set the timing. make sure you are getting proper advance both vacuum and centrifugal.
77 Macho Power Wagon LWB factory 440
70 Coronet 440 N code 3 speed
