B Body Hemi H pipe #2455254
02/21/18 08:18 PM
02/21/18 08:18 PM
Ohio
V
viperakron Offline OP
V
Ohio
Is the H pipe for a 66/67 the same as a 68/69. Wheel base the same etc?
Looking for a 66 Cornet and vendor only has them for 68.
Re: B Body Hemi H pipe [Re: viperakron] #2455266
02/21/18 08:39 PM
02/21/18 08:39 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
On wheelbase the 1966-1970 Dodge is 1" longer than Plymouth.
66-67 vs 68-70 The fuel tank is different, tailpipes are different. Are the mufflers in a slightly different position to set up the tailpipes correctly?
Re: B Body Hemi H pipe [Re: viperakron] #2455271
02/21/18 08:46 PM
02/21/18 08:46 PM
Ohio
V
V
Ohio
So is a 66/67 Dodge H pipe the same as a 68/69 Dodge? Just muffler exits different in 68/69?
Re: B Body Hemi H pipe [Re: viperakron] #2455274
02/21/18 08:52 PM
02/21/18 08:52 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
I don't know, but the WB is the same. They sell the same muffler for each year.
I'm wondering if the head pipe places the muffler in a different place or angle to set up the tailpipes.
Re: B Body Hemi H pipe [Re: viperakron] #2456092
02/23/18 01:17 PM
02/23/18 01:17 PM
Roseburg, Oregon
Tom Swope Offline
Tom Swope  Offline
Roseburg, Oregon
To answer your question. The replacement/after market hemi h-pipes are the same part number for 1966-70 Dodge or Plymouth. The muffler angles are not different for the 66/67 applications versus the 68-70 applications. The tailpipes are the difference for 66/67 applications as the fuel tank and gas filler tube are designed differently than the later models. In other words later 68-70 tailpipes will not fit 66-67 applications properly. As far as wheel bases are concerned, there are not two different h-pipes to accommodate the two wheel bases as there are not any fit issues for installing the h-pipe on either one.
Hope this information helps.
