Re: Guess my Dyno numbers
[Re: Chuck@Best_Machine]
#2458978
02/28/18 05:35 PM
02/28/18 05:35 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Anytime a hot/bigger motor runs a 4150 type carb they CAN go very rich due to the added velocity that larger cubes create and are more sensitive to tune from my experience. The RIGHT Dommy will smooth that right out..........
[Re: Thumperdart]
#2459029
02/28/18 07:30 PM
02/28/18 07:30 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
The AFR read out says lean, the BSFC says a little fat up high. Test,test and test some more until it goes slower or looses power, correct Maybe it needs a slightly bigger high speed bleeds I agree on a bigger CFM carb. to help eliminate the manifold vacuum increasing restricting the air flow into the motor
[Re: Cab_Burge]
#2459052
02/28/18 08:27 PM
02/28/18 08:27 PM
BradH
This has been debated / argued before, but you cannot tune a carb by BSFC #s. BSFC doesn't tell anything about the air-fuel ratio. It's simply a measure of efficiency of the amount of fuel used to make the power recorded. EDIT: LINK to article on BSFC vs Air-Fuel Ratio...
#2459067
02/28/18 09:06 PM
02/28/18 09:06 PM
BradH
... It was a Q950 Stock jetting was way to rich... How much did you have to lean it out from the standard tune? I'm a little surprised you said it was too rich from what I recall the out-of-the-box settings are.
[Re: Cab_Burge]
#2459085
02/28/18 09:56 PM
02/28/18 09:56 PM
Posts: 970 Farmington Hills, Mich
Chuck@Best_Machine
The AFR read out says lean, the BSFC says a little fat up high. Test,test and test some more until it goes slower or looses power, correct Maybe it needs a slightly bigger high speed bleeds I agree on a bigger CFM carb. to help eliminate the manifold vacuum increasing restricting the air flow into the motor I agree! Of course the customer will add a air cleaner and full exhaust and that will change things to so no reason to chase a couple HP onthe dyno and like most guys he will do a little tuning once it's in the car. Reliability and driveability are more important. Just for example, a A/SA Max Wedge on our dyno will make 595 hp and run 10.20 at 3400lbs. So how fast would you think a 3600 lb 4 speed Road Runner would go ?
[Re: BradH]
#2459091
02/28/18 10:06 PM
02/28/18 10:06 PM
Chuck@Best_Machine
... It was a Q950 Stock jetting was way to rich... How much did you have to lean it out from the standard tune? I'm a little surprised you said it was too rich from what I recall the out-of-the-box settings are. I believe it was 4 front and rear
#2459156
02/28/18 11:48 PM
02/28/18 11:48 PM
Posts: 2,458 Sydney,Australia
tex013
Sydney,Australia
... It was a Q950 Stock jetting was way to rich... How much did you have to lean it out from the standard tune? I'm a little surprised you said it was too rich from what I recall the out-of-the-box settings are. I believe it was 4 front and rear I am not surprised now by this . I had to pull 4 or 5 jets out of the front and maybe 2 rear when I went from 440ci to 505ci. Motor just works the carb harder especially if carburation is a little undersized . Tex PS : my 505 with a hair more comp and bit more cam makes 600-620 FWHP . With a 4150 carb , mufflers and exhaust to diff . I am not sure this one will go too much more .
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2459441
03/01/18 03:55 PM
03/01/18 03:55 PM
BradH
... It was a Q950 Stock jetting was way to rich... How much did you have to lean it out from the standard tune? I'm a little surprised you said it was too rich from what I recall the out-of-the-box settings are. I believe it was 4 front and rear I am not surprised now by this . I had to pull 4 or 5 jets out of the front and maybe 2 rear when I went from 440ci to 505ci. Motor just works the carb harder especially if carburation is a little undersized . Makes sense, in that I'd suspect that whomever is in charge of the calibration for those carbs probably isn't told the intended application is 500 cubes making 600++ HP. Yeah, the bigger engine would create more signal than the carb was originally tuned for, whereas a too-big carb would need to be richer to crutch the lack of signal.
[Re: DoubleD]
#2459444
03/01/18 04:03 PM
03/01/18 04:03 PM
Thumperdart
State of confusion
Because lean is Mean................! Ya, mean on rings, pistons and bearings............
[Re: Thumperdart]
#2459447
03/01/18 04:08 PM
03/01/18 04:08 PM
BradH
Because lean is Mean................! Ya, mean on rings, pistons and bearings............ I was going to say something along the same lines, but ya' treed me.
[Re: BradH]
#2459518
03/01/18 06:36 PM
03/01/18 06:36 PM
tex013
Sydney,Australia
.[/quote] Makes sense, in that I'd suspect that whomever is in charge of the calibration for those carbs probably isn't told the intended application is 500 cubes making 600++ HP. Yeah, the bigger engine would create more signal than the carb was originally tuned for, whereas a too-big carb would need to be richer to crutch the lack of signal. [/quote]
Spot on Brad , the too rich I encountered with the Modman and 440ci . Seen it a few times on the dyno , raw fuel/black smoke but AFR showing lean .
Tex
[Re: tex013]
#2459578
03/01/18 08:41 PM
03/01/18 08:41 PM
Thumperdart
State of confusion
Makes sense, in that I'd suspect that whomever is in charge of the calibration for those carbs probably isn't told the intended application is 500 cubes making 600++ HP. Yeah, the bigger engine would create more signal than the carb was originally tuned for, whereas a too-big carb would need to be richer to crutch the lack of signal. [/quote] Spot on Brad , the too rich I encountered with the Modman and 440ci . Seen it a few times on the dyno , raw fuel/black smoke but AFR showing lean . Tex [/quote] NO outta the box carb will be ideal for YOUR application at least not any that I've heard or seen.....
[Re: Thumperdart]
#2459798
03/02/18 06:37 AM
03/02/18 06:37 AM
tex013
Sydney,Australia
Makes sense, in that I'd suspect that whomever is in charge of the calibration for those carbs probably isn't told the intended application is 500 cubes making 600++ HP. Yeah, the bigger engine would create more signal than the carb was originally tuned for, whereas a too-big carb would need to be richer to crutch the lack of signal. Spot on Brad , the too rich I encountered with the Modman and 440ci . Seen it a few times on the dyno , raw fuel/black smoke but AFR showing lean . Tex [/quote] NO outta the box carb will be ideal for YOUR application at least not any that I've heard or seen..... [/quote] You got that Dom June is off season , so then i will set up intakes to try dominator and modman again Tex
