Gasoline Fumes #2454854
02/20/18 11:44 PM
02/20/18 11:44 PM
Central New York
bfury Offline OP
bfury  Offline OP
Central New York
My 76 Dart Sport has had the vapor canister removed. The lines leading to it were left open in the engine compartment. I plugged them. The car smells of fumes all the time it's driven. Other than finding a new cannister, has anyone come up with a solution?
No Stock
Re: Gasoline Fumes [Re: bfury] #2454922
02/21/18 02:22 AM
02/21/18 02:22 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
maybe the plugged lines are causing pressure to build up and forcing fumes out of the tank.
Re: Gasoline Fumes [Re: bfury] #2454931
02/21/18 02:59 AM
02/21/18 02:59 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
You could use a 2 or 3 nipple valve cover breather and hook the 2 larger lines there. You need to figure out which line hooks the highest in the tank, not perfect but better than the pressure you are building now.
Re: Gasoline Fumes [Re: 4406bbl] #2455065
02/21/18 01:43 PM
02/21/18 01:43 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That only works if the other valve cover breather is connected to the engine air filter or carb.
If he has an open breather on the other side he will still get the fumes.
- Stu Harmon
Re: Gasoline Fumes [Re: bfury] #2455442
02/22/18 03:07 AM
02/22/18 03:07 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Did it smell before?Tailpipes cure many aromas inside the car!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Gasoline Fumes [Re: feets] #2455453
02/22/18 03:32 AM
02/22/18 03:32 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
The 2 and 3 nipple breathers have a large nipple that must be hooked to the air cleaner, the other side must have a working pvc valve. You MUST make sure the tank line does not leach raw fuel into the motor, crankcase explosions, diluted oil can result.
Re: Gasoline Fumes [Re: bfury] #2455487
02/22/18 07:15 AM
02/22/18 07:15 AM
Central New York
bfury Offline OP
bfury  Offline OP
Central New York
I will have to check the breather. It has an Edelbrock mesh type air cleaner, no connection to the breather. I guess I will explore the idea of some kind of cannister or vapor separator. Thanks for all the suggestions.
No Stock
Re: Gasoline Fumes [Re: bfury] #2455559
02/22/18 12:58 PM
02/22/18 12:58 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I disconnected mine, plugged the lines back at the tank and changed to an aftermarket vented gas cap. With the stock cap, on cool days I was getting vacuum building up in the tank from no vent and the fuel pump drawing out of the tank and on warm days I would get pressure in the tank.
Re: Gasoline Fumes [Re: DaytonaTurbo] #2456579
02/24/18 11:32 AM
02/24/18 11:32 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I did an air trap loop for my tank with the fuel filter at the end to keep dirt out. Maybe you could do the same thing.
I tried to post a picture I found online but I'm having trouble.
