Bent strut rod #2454461
02/20/18 10:25 AM
02/20/18 10:25 AM
nj
MoJoe Offline OP
MoJoe  Offline OP
nj
I have a pretty badly bent strut rod...Can these be straightened?
Re: Bent strut rod [Re: MoJoe] #2454554
02/20/18 01:26 PM
02/20/18 01:26 PM
Trumussia
jcc Offline
No politics
jcc  Offline
No politics
Trumussia
Yes, assuming no metal damage, and any length change does effect alignment to a degree. Strut in normal use is loaded in tension.
This a tow truck driver aggressive/lazy tie down issue?
"Perfection is the enemy of Excellence" German Engineer
Re: Bent strut rod [Re: MoJoe] #2454660
02/20/18 04:14 PM
02/20/18 04:14 PM
Caldwell, Idaho
67R/T4speeder Offline
Caldwell, Idaho
I just took these out of a car yesterday, I think I will replace them and the control arm. The old ones will be punch material.
Re: Bent strut rod [Re: MoJoe] #2454681
02/20/18 04:58 PM
02/20/18 04:58 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
yeah, i wouldn't bother with any of that stuff. it looks like one control arm might be straight.
how does the k-member look where the strut rod bushing sits???
Re: Bent strut rod [Re: krautrock] #2454784
02/20/18 08:59 PM
02/20/18 08:59 PM
nj
MoJoe Offline OP
MoJoe  Offline OP
nj
That is some beat up stuff. Mine is really not so bad then... a little on one end. I was wondering how it would bend...some tow truck driver!
brake line clip & retainer locations
by buzz440. 01/23/20 12:27 AM
69 Roadrunner Interior Panel Fitment Issue
by BigDaddy440. 01/22/20 10:12 PM
B body heater box
by fastmark. 01/22/20 08:24 PM
Door panel identification help.
by SKR8PN. 01/22/20 07:55 PM
Moparts Recent Posts
Aluminum 8 3/4 center section P4876445
by Doc Fiberglass. 01/23/20 01:10 AM
Wow, '18 WB Hellcat with 101k miles
by Doc Fiberglass. 01/23/20 01:04 AM
by BigDaddy440. 01/23/20 01:02 AM
Excessive braking calculation?
by Doc Fiberglass. 01/23/20 12:53 AM
