Air checking 904 question #2453596
02/18/18 07:34 PM
02/18/18 07:34 PM
Memphis,TN
J. Hammer Offline OP
Memphis,TN
I'm building a 904 and may have a problem during air checking the clutches. The direct seems fine,engages firmly and no air escaping. The rear clutch is a different story. The clutch engages but air escapes from the port next to the port that I apply air pressure, this is the port that goes to the converter? Anyone run into this?
Re: Air checking 904 question [Re: J. Hammer] #2453619
02/18/18 08:53 PM
02/18/18 08:53 PM
BLACKHEMIRR Offline
BLACKHEMIRR  Offline
Sounds like you might have a broken sealing ring on the input shaft, and have air leaking into the pump housing.
Re: Air checking 904 question [Re: BLACKHEMIRR] #2453741
02/19/18 01:17 AM
02/19/18 01:17 AM
Memphis,TN
Memphis,TN
I wish it was that simple. The rings look fine but I have swapped to the old ones with no change.
Re: Air checking 904 question [Re: J. Hammer] #2453813
02/19/18 10:06 AM
02/19/18 10:06 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Teflon or steel rings? Do they have grease/assy lube on them? How is inside surface where they seal against?
Doug
Re: Air checking 904 question [Re: J. Hammer] #2454358
02/20/18 01:45 AM
02/20/18 01:45 AM
Memphis,TN
Memphis,TN
The rings are metal and well lubed. The drum had a small amount of wear,I gently cleaned it up with 400 grit.
Re: Air checking 904 question [Re: J. Hammer] #2454377
02/20/18 02:17 AM
02/20/18 02:17 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Are the pump parts and input shaft original to that trans?
Re: Air checking 904 question [Re: John_Kunkel] #2454383
02/20/18 02:23 AM
02/20/18 02:23 AM
Memphis,TN
Memphis,TN
The original pump was replaced with a transtar rebuilt pump. Input shaft,drums are original to the trans.
Re: Air checking 904 question [Re: J. Hammer] #2454430
02/20/18 07:23 AM
02/20/18 07:23 AM
BLACKHEMIRR Offline
BLACKHEMIRR  Offline
You might have to disassemble the pump and make sure there's nothing going on where the clutch hub contacts the pump body. I think that is just a metal to metal seal, correct? Maybe there is a crack or piece of debris in that area.
Re: Air checking 904 question [Re: J. Hammer] #2455245
02/21/18 08:02 PM
02/21/18 08:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There was a change in the support and rings, might have a mismatch of parts.
Re: Air checking 904 question [Re: John_Kunkel] #2456930
02/24/18 08:50 PM
02/24/18 08:50 PM
Memphis,TN
Memphis,TN
I swapped the single ring on the input shaft to a teflon ring from the small end of an accumulator piston and no air leakage can be heard. There is a tan plastic ring that has flat cut ends that seems to work as well. What ring would be the correct choice in that location? Thanks for the help.
Re: Air checking 904 question [Re: J. Hammer] #2457024
02/24/18 11:28 PM
02/24/18 11:28 PM
A727Tflite Offline
A727Tflite  Offline
Square cut seals (usually "plastic") should have the ends butted when placed in their respective bore.
The metal variety with locking ends should have a gap between the locking tabs when placed in their bores.
Re: Air checking 904 question [Re: A727Tflite] #2457451
02/25/18 07:29 PM
02/25/18 07:29 PM
Memphis,TN
Memphis,TN
Thanks, I knew that but I don't do many trans builds so it never hurts to give me a reminder.
