Re: What headers are you running? [Re: Ari440] #245263
03/09/09 12:09 PM
03/09/09 12:09 PM
Hunt Valley, Maryland
1fastrunner Offline OP
this is my 440 in my 72 ROADRUNNER soon it will be running
440 , 11.1comp ,557 cam , stage six heads, M1 750 ,cppa/tti A body headers
A Body headers in a B body?
Re: What headers are you running? [Re: 1fastrunner] #245264
03/09/09 12:18 PM
03/09/09 12:18 PM
long island NY
Ari440 Online content
Ari440  Online Content
long island NY
yes
I had these headers in my duster , sold them and bougth them back
the cppa/tti hug the moter real good there in there now !!
I guess you can do it with these headers only !
1.39 9.85 - 137 mph
Re: What headers are you running? [Re: 1fastrunner] #245265
03/09/09 12:45 PM
03/09/09 12:45 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
What engine size and hp range are you at?
What exhaust size,converter stall,and gear ratio are you running?
What headers are you running now?
My motor is a 440, soon to be rebuilt. The car is a 4-speed with 3.23 rear. I'm not sure what to do to the motor yet, but he's what I think it has now: 30 over, stage IV heads, lunatti cam, holley 750 dp and arias pistons.
I'm looking to run on pump gas and the car won't see the track. I'm trying to keep my budget down and I'm looking for suggestions. My exhaust is currently 2.5, but I plan to upgrade to 3 in the future.
Thanks,
check out the hedman elites. thick flanges, heavy wall tubes, ceramic coated for less than $400. IIRC they don't go under the steering, either. they're only 1 3/4", which is fine for a mildish street BB. for heads, do you mean stage VI's? for the money, you'd be better off going with edelbrocks
2017 Grand Cherokee Overland
Re: What headers are you running? [Re: patrick] #245266
03/09/09 12:48 PM
03/09/09 12:48 PM
They are Stage IV's
Re: What headers are you running? [Re: landon1] #245267
03/09/09 01:09 PM
03/09/09 01:09 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
not a 71,but i run DOUG'S ceramic coated on my 70 runner 440 from summit,fit excellent but must use mini starter,excellent quality thick flanges,plug boots no longer burn ,300.00 less then tti
Re: What headers are you running? [Re: meepmeep70] #245268
03/09/09 02:07 PM
03/09/09 02:07 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
68 GTX love my TTI's
Re: What headers are you running? [Re: Dodgem] #245269
03/09/09 02:08 PM
03/09/09 02:08 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
In the parts section a guy has a set of new in the box heddmans for a BB for $75
Re: What headers are you running? [Re: 1fastrunner] #245270
03/09/09 02:30 PM
03/09/09 02:30 PM
Temple, Texas
scoutsr2 Offline
scoutsr2  Offline
Temple, Texas
I originally purchased a set of Hedman Super Elites for my Charger only to find that the #6 plug would not clear the header when using edelbrock aluminum heads. Had to clearance around the starter and the PS gearbox but they look good. I ended up ordering a set of TTI which, I think most will agree are the best Mopar headers on the market. If a set of ceramichrome hedmans stike your fancy PM me and maybe we can work something out.
Re: What headers are you running? [Re: scoutsr2] #245271
03/09/09 04:58 PM
03/09/09 04:58 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Why does Hedman spell their product HEDDers and everyone else calls theirs headers?
Keep old mopars alive.
Re: What headers are you running? [Re: scoutsr2] #245272
03/09/09 05:48 PM
03/09/09 05:48 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Be careful with Elites, they specifically say they do not work with Edelbrocks on the listing.
I have run the regular coated Hedmans on both of my B-body's and they have been great. Better coating than Hooker and you can run the fast ratio pitman arm with Hedman's but not with TTI or Hooker. No need to spend $800 on headers for 90%street/10%strip 440.
Re: What headers are you running? [Re: Viol8r] #245273
03/09/09 06:05 PM
03/09/09 06:05 PM
Central NC
gch Offline
gch  Offline
Central NC
I run 1 7/8 headers on a 440.1 3/4 will work fine and probably fit better.You won't lose much and you are not going to the track anyway.
I have always used Hooker or tti.The hedman elites are a nice 1 3/4 header.Doug's are good as well.Buy which ever one you can get the best deal on.
Try jet-hot's website.They usually have some in stock already coated for a discount.
Nice car btw!
Re: What headers are you running? [Re: 1fastrunner] #245274
03/09/09 06:39 PM
03/09/09 06:39 PM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
Re: What headers are you running? [Re: RussW] #245275
03/09/09 06:47 PM
03/09/09 06:47 PM
IL
71383beep Offline
71383beep  Offline
IL
running TTI 1 7/8 on the 383. Went in fairly eaily. Had to get the motor up and rotate the wheels (forgot to do this at first causing quite a littany of swears!) Running a Dakota starter so no real issues other than getting the wiring done was kind of a pain.
Only major problem is that the #3 plug lies RIGHT on the header and burns the wire. A shorty plug should work better with boots...add it to the list.
The old MP headers I had leaked like a sieve and could give you heat stroke when you opened the hood. Now no leaks and the engine bay is much cooler.
A lot of money but a very good product IMO.
'73 GK6 Challenger Rallye - 340 4-Speed
Re: What headers are you running? [Re: 71383beep] #245276
03/09/09 08:02 PM
03/09/09 08:02 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I always bought the headman hookers summits... and they were every single one a royal pain to install, rust out in no time flat and drag on everything. On this car I was fed up and swore off ever useing headers again, then I saw BondoBob selling his used TTIs and I caved into all the hype, he gave me a good deal they showed up looking almost new, 3 years later they are the best looking thing in my engine compartment, they fit like a glove, after instaling them I stood there in amazement at how fast I had just installed a set of headers. They don't drag and I don't have to unbolt them and hold them out of the way to change a starter, as a matter of fact I don't really have to get under the car to change the starter. If you can afford them I say go for them.
Re: What headers are you running? [Re: HotRodDave] #245277
03/09/09 09:15 PM
03/09/09 09:15 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Summit brand took 10 minutes to install by myself. After the engine and car were jacked up of course
Re: What headers are you running? [Re: Mr.Yuck] #245278
03/09/09 11:11 PM
03/09/09 11:11 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
Summit here on my 69 B-body.
Fit was fixed with a hammer. Starter access is ruff... but they work.
i've heard a lot of people talk about getting out the hammer and how installing headers was such a pain...i had no problems with the install, no modifications of any kind to the headers or other parts. i believe i read that all of the headers produced for the BB mopars are virtually the same, yet so many are having problems
No 2 mopars are the same. Maybe yours fit because the guy who welded up the subframe was less drunk/stoned then the guy who did mine.
Would i buy another set of summit headers? For $70 bux ya. Would i expect them to fit like a $700 set of TTI's? Heck no.
yeah 'aint that ture "no two are the same" and even the high mighty TTi's have issues. For the price they charge that entire exhaust system should jump out of the box and install itself while you drink a cool one.
I couldnt help but laugh at that one! A friend of mine had some TTI's in a 68 Charger with a 440 and he had to ding 'em to make 'em fit.
And it didnt seem like he had any better clearance at the starter than any other header that I have seen in the past.
