295/65R15 M/T ET rim size #2450960
02/12/18 10:58 PM
02/12/18 10:58 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Seems like 8-10.5 is the rim-width range they call for; who's running what size? I've heard 10" wide is best.
Given the rearend width & leaf spring location (3/4" relocation brackets) that's with on this car (Duster), 10" wide with a 5" BS would be perfect, but that's a really hard BS to find; 4.5" avoids spacers, so that's next best...
(I've already pie-sliced the front of the opening, trimmed the wheel-opening flange, and rolled its upper edge, so I have 13.5" of wheelhouse width, and there's 6.5" from drum face to springs.)
Re: 295/65R15 M/T ET rim size [Re: topside] #2450991
02/12/18 11:31 PM
02/12/18 11:31 PM
I ran that size on my 12.0 inch wide Weld rims on my Duster with ladder bars and full tubs to the stock location inner sub frames, the M/T 315x60x15 ET street radials worked better on that car though up
Re: 295/65R15 M/T ET rim size [Re: topside] #2451030
02/13/18 12:30 AM
02/13/18 12:30 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have 295/65s on 10" Cragars. The edges are pulled up off the pavement with 18-20 lbs. I have to let them down to 12 lbs or so to get them to lay the full face on the pavement. And 12 lbs is too low.
What rims are you considering? Most companies will build your backspace on a special order. Cragar did mine.
You may want to consider the 275/60 Rs on a 10" rim. They would lay better with the 10" rims IMHO. The only reason I don't do that myself is because I like the look of those huge 295s on the back of the Cuda.
Master, again and still
Re: 295/65R15 M/T ET rim size [Re: topside] #2451069
02/13/18 02:08 AM
02/13/18 02:08 AM
New York
polyspheric Offline
polyspheric  Offline
New York
One of the decisions is do you want the tire diameter to grow (like you may run out of gear)?
If yes, narrower rim will get bigger at speed.
Otherwise, rim width = sidewall width is safe. 295mm = 11.6".
Boffin Emeritus
Re: 295/65R15 M/T ET rim size [Re: topside] #2451070
02/13/18 02:16 AM
02/13/18 02:16 AM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
295 I would run on a 10 inch wheel minimum, a 12 inch would be better. I run 275’s on a 10 inch wheel and to me it’s a great combo....
A new iron curtain drawn across the 49th parallel
Re: 295/65R15 M/T ET rim size [Re: topside] #2451109
02/13/18 10:59 AM
02/13/18 10:59 AM
an8sec70cuda Offline
M/T recommends an 8.5" wide rim for that tire, but most agree wider is better. I run 8.5" wide rims on my cuda w/ the 295-65 radial basically b/c of my stock width rear, a 10" won't fit.
Seems to work ok though. Best 60 foot footbraking on motor is 1.320. Best on nitrous so far is a 1.30 w/ a very delayed nitrous hit.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 295/65R15 M/T ET rim size [Re: topside] #2451112
02/13/18 11:14 AM
02/13/18 11:14 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
same size but hoosier radials on 8" rims. no problem
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: 295/65R15 M/T ET rim size [Re: Den300] #2451127
02/13/18 11:46 AM
02/13/18 11:46 AM
Dirty Dena, Maryland
dodge turbo Offline
dodge turbo  Offline
I run mine on a 10. It spread the tire out more then the 8 I used to run
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: 295/65R15 M/T ET rim size [Re: dodge turbo] #2451133
02/13/18 11:58 AM
02/13/18 11:58 AM
Motor City
6PKRTSE Online content
6PKRTSE  Online Content
Motor City
I had them stretched onto my 12" wide rims at one time. I now currently have 315's & they fill the wheel well much better.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 295/65R15 M/T ET rim size [Re: 6PKRTSE] #2451168
02/13/18 01:28 PM
02/13/18 01:28 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
same tire on a 10" rim, contact patch looks good to me...
Looks small compared to the 315 or 325 I used run
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: 295/65R15 M/T ET rim size [Re: dodge turbo] #2451653
02/14/18 01:52 PM
02/14/18 01:52 PM
E
earlymopar Offline
earlymopar  Offline
E
Great looking pickup turbo!
- EM
Re: 295/65R15 M/T ET rim size [Re: topside] #2451755
02/14/18 06:25 PM
02/14/18 06:25 PM
Akron, Ohio
ProSport Online content
ProSport  Online Content
Akron, Ohio
I had them on a 10" rim on my Dart.
Re: 295/65R15 M/T ET rim size [Re: topside] #2451803
02/14/18 07:53 PM
02/14/18 07:53 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
My 'Cuda has the MT 295/65-15 drag radial,on a 10" rim, 6.5" BS, stock width E-body 8.75, springs inboarded 3", stock wheel tubs, drives great, rides nice, mid-10 3800lbs.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: 295/65R15 M/T ET rim size [Re: johnnycuda] #2451862
02/14/18 09:56 PM
02/14/18 09:56 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Just for reference:
Re: 295/65R15 M/T ET rim size [Re: topside] #2451908
02/14/18 11:39 PM
02/14/18 11:39 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Man, you guys have some gorgeous cars! I appreciate the responses; funny that the only Duster so far is Cab's which is a very different animal than this car. I saw one Duster with 325s under it (!) but the guy didn't know the wheel size or BS.
Once I get the diff, axles & drums back in it I'll re-measure everything for the 5th time and maybe even fab a cardboard example to try to only do this once. Pretty much gotta go 15x10, just need to nail the BS.
Re: 295/65R15 M/T ET rim size [Re: topside] #2451915
02/14/18 11:46 PM
02/14/18 11:46 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I am shooting for a 295/65 on a 10" wheel on my Bee. My signature pic is 276/60/15 on an 8"(I think)wheel. I like the width of a 315, but I don't like the short tire.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 295/65R15 M/T ET rim size [Re: OhioMopar] #2451955
02/15/18 01:05 AM
02/15/18 01:05 AM
I think that both of the sets of the M/T Street radials tires I ran(295x65x15, 315x60x15) had the same circumference when measure with a seamstress tape, but maybe not as that was a long time ago confused
I have 96.0 inch circumference for both in my mind, the 315x60x15 on a ten inch wide rim and the 295x65x15 on the 12 inch wide rims confused
I ran 4.10 rear gears in the car most of the time and I would see a 500 RPM drop switching from the 315x60x15 E.T. Street radials to the larger diameter 10.5x31x15W M/T slicks which had right at 102 inch circumference on the ten inch rims, no real MPH change in the 1/4 mile though that I remember, just RPM recorded on the VDO playback tach in the car shruggy
Re: 295/65R15 M/T ET rim size [Re: Cab_Burge] #2452017
02/15/18 04:58 AM
02/15/18 04:58 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Turns out it was 315/50/15 that are shorter. 315/60's are 29.88 vs. 30.1 on the 295/65.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 295/65R15 M/T ET rim size [Re: topside] #2452069
02/15/18 11:34 AM
02/15/18 11:34 AM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
I run an 8" wheel. I know it's probably too narrow but it's what I can fit with the b body Dana and offset shackles. I'd like to go to a 10" wheel but I don't want to hack on my car..
Re: 295/65R15 M/T ET rim size [Re: topside] #2452081
02/15/18 12:29 PM
02/15/18 12:29 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I taped a piece of cardboard on the floor and then drove the car on it, positioning a rear wheel on it. Then I pulled the wheel and used a plumb bob to mark out everything on the cardboard.
The spring, hub, wheel well, etc. That is the most accurate way I have found to KNOW where everything is and to have a constant reference when researching wheels.
And be sure to do both sides to catch any differences.
